header mufflers
Old May 8, 2013 | 05:14 PM
alpinestars199's Avatar
Car: 89 firebird formula
Engine: 305 5.0
header mufflers
Hey guys sorry for being a pain in the a** but I had a quick question. I was looking at header mufflers read about some called hornies. My question is having a muffler right off the headers ok. I know about the sound but what about back pressure in the exhaust. I live in the middle of no where and I'm exempt from emissions so any thoughts?
Old May 9, 2013 | 08:57 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: header mufflers
never heard of "header mufflers" , expand/explain please .
Old May 9, 2013 | 03:00 PM
86iroc2try's Avatar
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
Re: header mufflers
Purple hornoes by flowtech.
Theyre cheao and not too loud...you may hit the floorpan with them...thats the only issue
Old May 9, 2013 | 05:04 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: header mufflers
I had header mufflers back in the day.
Okay for the money and ease of installation, at least in older cars. Not sure if they will fit as stated above.
Are they the best? No. Would a fill exhaust be better? Probably.
Old May 9, 2013 | 06:29 PM
UNCLE TOM's Avatar
Re: header mufflers
I had to look this one up , I thought I had heard it all . the only place I can see them being used is a dirt/rock crawler open buggy . no place on a passenger car . exhaust should exit to the rear of passenger compartment . exhaust gases in an enclosed vehicle have been known to kill people . do not use , good luck .
Old May 9, 2013 | 06:41 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Re: header mufflers
back in the day I had "Cherry bomb" glass packs on an old Charger I had...they had a 3 bolt flange and bolted right up to the header collector. I ran straight pipe from there to about the rear axle with two turndowns.
It was pretty obnoxiously loud...... -I have no idea how they'd ever fit a Thirdgen and have any clearance...
Old May 9, 2013 | 06:45 PM
Car: 1971 Camaro
Engine: 427
Re: header mufflers
Header mufflers have been around since the 1960's.
There are literally thousands of cars running around with turndowns in front of the axle, and probably just as many pos's with little to no exhaust.
Old May 9, 2013 | 06:48 PM
Car: 1971 Camaro
Engine: 427
Re: header mufflers
Back in the day my dad had some on his 55 bel air. He took semi stacks and welded them on the end, at an angle so they cane out in front of the rear tires.
Old May 21, 2013 | 12:52 PM
obliovionox09's Avatar
Car: 1984 camaro
Engine: 1970 l48 with vortec heads
Transmission: 700-r4 from a diesel
Re: header mufflers
I am running dual purple hornies on my 84 camaro with hedman long tubes, had to get extenders with a ddrop of like 6 or 7 inches but they are about 2.5- 3 inches off the ground. I have to shorten the straight pipes coming out of them, they are dragging the ground under the rear axel, im going to have them exit at the back of the doors.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Tarizza
Sep 24, 2015 12:57 PM
cstrobel65
Sep 16, 2015 11:54 AM
blackandblue02
Sep 10, 2015 08:19 PM
89fast5oh
Sep 8, 2015 09:55 AM
