hooker 2055. Is there a hooker equivalent without a.i.r.?
Old Jun 15, 2013 | 08:26 PM
devilschariot's Avatar
Engine: 305 tpi
What is the hooker 2055 equivalent without the A.I.R. pipes?
There have to be so many guys out there wanting to know this without wading through pages and pages of law debates, emissions controls, and righteous owners declaring any mod to the smog system a modern day blasphemy.
Also, if you plan to tell me to "search for it" I will pre-emptively declare a "**** off" and sentence you to 4 hours of uneventful websearching and condemn you with that nagging feeling that you get when your question is never answered and you're to blame for even asking.
Last edited by devilschariot; Jun 15, 2013 at 08:36 PM. Reason: if you cant say something nice dont say anything at all
Old Jun 15, 2013 | 08:38 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: hooker 2055. Is there a hooker equivalent without a.i.r.?
Hooker 2460. But the y-pipe that comes with the 2055 is better, so most people go with those.
Old Jun 15, 2013 | 09:18 PM
Engine: 305 tpi
So thanks for the straight answer. I searched for awhile now after you pointed this out and my conclusion is that a custom 3" y pipe for the 2460 is not available as is for the 2055s?
Or did I completely miss something?
Old Jun 15, 2013 | 09:33 PM
Dabesiv's Avatar
Car: 1982 Camaro Berlinetta
Engine: GM crate motor Goodwrench 5.7 350
A custom one is available, as in custom from a shop, or yourself if you have the equipment to do it. There isn't a Y pipe made by Hooker for the 2460
Engine: 305 tpi
The previous owner deleted cat...I want headers. A.i.r. not functioning and dont need it to.
I think its silly to pay 479.99 for headers that are not what I want for the y pipe than pay the 169 or 200 for the 2460s.
Is there not an option that comes out under 479 while getting exactly what you need?
Old Jun 15, 2013 | 09:41 PM
Engine: 305 tpi
Yeah, just saw your post so my last one means nothing.
Okay. Thanks!
I thought I wasn't searching hard enough...turns out I was searching too much.
Old Jun 15, 2013 | 09:47 PM
Dabesiv's Avatar
I'm in the same boat, haven't needed A.I.R for a while as I got a new cat that doesn't use it and had been searching for a bit, tried to save you some time. If you plan on keeping these headers for a while, invest in ceramic coating them properly or get those already coated ( I think Pep Boys does special order on them), inside and out, it will keep the temp down, prevent rusting, and make for better air flow but will raise the price. Summit has them for cheap because they have no Y pipe and are painted not coated.
Old Jun 15, 2013 | 10:35 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Chexk here:
https://www.thirdgen.org/forums/engi...headers-y.html
Old Jun 15, 2013 | 11:11 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Y- pipe for 2460's:
http://www.jegs.com/i/Hooker-Headers/520/16767/10002/-1
Old Jun 15, 2013 | 11:24 PM
Dyno Don's Avatar
Originally Posted by TreeFiddy
That Y pipe is only 2 1/2"
Old Jun 15, 2013 | 11:27 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Just buy a set from Don and have the best.
Old Jun 16, 2013 | 05:14 AM
Dabesiv's Avatar
From what I have heard over the years, they are well worth their price.
Old Jun 24, 2013 | 02:15 PM
dmwracing42's Avatar
Car: 1984 Trans Am
Engine: 355
Axle/Gears: 10 Bolt, Torsen Diff, 3.73's
I'm confused as to why everyone says Don's are the best. His Y is also 2.5", unless I'm completely missing something. Not a knock on Don, I have heard great things, I'm just confused why everyone condemns the 2460's for the exact same thing.
Old Jun 24, 2013 | 03:33 PM
Dabesiv's Avatar
I think the big part it that they are custom made for our cars, and instead of taking it to a shop to make a brand new y pipe you can hook it all up and just get the new pipes welded to the old
Old Jun 24, 2013 | 10:36 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
2460 uses thicker gauge steel. They are heavier, flow less, and have the added expense of needing a Y-pipe.
Old Jun 25, 2013 | 10:12 AM
Dyno Don's Avatar
But the Y-pipe goes to a 3" outlet not 2 1/2"
no green
Jan 9, 2016 09:22 PM
Johnny*G
Oct 20, 2015 12:37 PM
thekurlyone
Sep 30, 2015 12:54 PM
Chevykid810
Sep 28, 2015 12:57 PM
64goatman
Sep 9, 2015 01:09 PM
