Dumb Question Here...
Old Jun 26, 2013 | 05:07 PM
DumbQuestion's Avatar
Hello 3rd Gen'ers...
Got a question for ya... I have a 1991 RS with a 305V8... two years ago It squeaked by on its smog test but only after replacing that cat.
Today took it in and it failed, went to an exhaust shop and they say the cats dead and needs to be replaced...
But the kicker is, the guy at the Smog shop says "I thought these cars were supposed to have another cat, I see the main one here under the passenger seat, but isnt there supposed to be another one? Unless its right at the manifold."
I know nothing when it comes to exhaust but google isnt helping me out much. Would appreciate the help so I dont waste his time and more importantly mine with a retest if its still going to fail.
Thanks in advance
Old Jun 26, 2013 | 05:14 PM
-AO-'s Avatar
Car: 3rd gen!
Engine: SBC
Transmission: yes
Axle/Gears: yes
Re: Dumb Question Here...
Every 305 TBI car came with only 1 cat. Some TPI cars came with 2.
Old Jun 26, 2013 | 05:33 PM
Throttlebody here...
Wonder why the damned thing ate through a brand new Cat Converter so fast...
Old Jun 26, 2013 | 06:36 PM
There's only the one.
They're STOOOOOPID CHEEEEEEEEP though; if it needs one, just get one and change it out. Put it behind you and move on. Summit is your friend when it comes to thing like that.
Old Jun 26, 2013 | 07:34 PM
Guest
Guest
Posts: n/a
Move to a better state.
(i.e. one with no testing)
Old Jun 26, 2013 | 09:19 PM
Military. I have little say in the matter.
Otherwise I'd be in another state and have strait pipes.
Old Jul 23, 2013 | 09:49 AM
ImBrandon's Avatar
Car: 1991 Pontiac Trans Am
Axle/Gears: 3:42
Get a magnaflow hi flow cat. That got me to pass.
Old Jul 23, 2013 | 10:26 PM
Guest
Guest
Posts: n/a
straight pipes are -fun-...for about 2...3 days...
(in a DD)
Old Jul 25, 2013 | 09:32 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
If your 1 or 2 year old cat is already shot, you've got other problems, and just throwing a new cat on the car before every inspection isn't the right way to fix it. You're better off finding why you keep ruining cats. Generally running rich will kill a cat, and the most common reason to run rich is an old/tired oxygen sensor. Sometimes they won't throw a code even when they're no longer functioning properly. The best solution would be to replace the cat, then use a scan tool to monitor engine performance while you drive to try and figure out the real problem. If that's not feasible, at least toss in an O2 sensor when you change the cat if you haven't replaced it in a while.
morrow
Jan 13, 2024 12:29 PM
92GTA
Apr 9, 2016 07:39 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
