Which spark plugs for edelbrock headers?
Old Nov 15, 2013 | 10:39 AM
88'camaro305TBI's Avatar
Car: 88 IROC
Transmission: auto
What spark plugs do you guys run with the edelbrock TES headers? Will the stock length be fine? or should I get the Accell header plugs?
thanks
Old Nov 15, 2013 | 11:06 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: Which spark plugs for edelbrock headers?
thanks
I don't have an answer for you (as I do not have those headers). However, I am curious: What about these headers calls for a special type of spark plug? Are they shaped in a way that prevents certain types or something?
Just for my own information.
Old Nov 15, 2013 | 11:33 AM
Mad Myche's Avatar
Car: 89 Camaro RS
Engine: 2.8 V6
Transmission: Automatic
Originally Posted by RedLeader289
...I am curious: What about these headers calls for a special type of spark plug? Are they shaped in a way that prevents certain types or something?
There are 2 reasons to possibly want to change plugs due to manifold changes; the primary one would be changing the heat-range of the plug due to changes in the ambient temperature around the plug and the other would be due to shear accessibility or lack thereof in regards to the plug
Old Nov 15, 2013 | 11:45 AM
Car: 88 IROC
Transmission: auto
It is only for accessibility and fitment issues.
For people that have these headers, what plugs do you use?
The heads and engine are otherwise stock.
thanks
Old Nov 15, 2013 | 08:21 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
I have used bosch with those headers in the past-they are shorter than typical stock replacements. I have not tried stock replacement plugs with these headers,but looks like they should fit(started using the short plugs when I had SLP headers)
Old Nov 16, 2013 | 12:38 PM
Car: 88 IROC
Transmission: auto
I ended up getting the Accel short style header plugs.
Thanks everyone for your help.
Old Nov 16, 2013 | 02:22 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Due to header design, #6 and #8 are almost completely blocked by the #4 primary tube, making it very difficult to change the rear plugs on the passenger side.
I have standard length NGK plugs with mine. I use either a pass-through socket or a ratcheting box end wrench to change them. I still have to do it from under the car.
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
tricky1
Aug 23, 2015 01:17 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
