SLP Header install questions.
Car: 87 irocz 305 5.0 5 speed G92 option
Engine: 305 tpi
Axle/Gears: 9 bolt 3.45 factory gears
So I just picked up a pair of SLP headers for my 87 Iroc LB9 G92 car. I have been doing research on the board and have put together a list of things that I will be needing to install. I bought headers although my dad told me not to (he's been a hot-rodder his whole life and owns several Camaros) because he says headers always leak and the bolts come loose. With this said he is not going to be helping me install them and I want to prove him wrong and install these headers with parts that will insure my SLP headers will not leak and the bolts will not come loose.
From what I have gathered using the search feature this is what I have been able to come up with that I will need that will insure me a virtually leak proof header job:
Percys Dead-Soft Aluminum Header gaskets
Stage 8 Locking Header Bolts
Do the copper gaskets work as well as the aluminum gaskets?
Will the install require anything else?
Engine: 305 tpi
Re: SLP Header install questions.
I have also read to use regular 1 inch header bolts with a drop of anti-seize. Will this method insure the bolts will not come lose? Also have read to use locktite blue. I am just concerned the locktite might cause the bolt to become stuck. Will locktite cause the bolt to become stuck?
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Well I have used the graphite gaskets with the stage 8 bolts with good success. With the stage 8 bolts you can use the anti-seize if you want.
Engine: 305 tpi
I see awesome thank you! Which brand graphite gasket did you use? Fel-pro?
Engine: 454-350
I have forgotten the brand name but they where pretty thick graphite and soft. They compressed down nicely and didn't blow out. I would Google it and see what comes up.
Car: 89 Firebird Formula
Engine: 383 tpi vortec heads Xr 269 cam
I am trying to install Dyno Don headers and thinking of using either from Summit
Seal 4 good 66011 Aluminum
or
Mr Gasket Ultra Seal 5903 Graphite Impregnated
Not sure which one is better
or
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
How about bolts from summit
ARP 100-1109 or STG 8911a
Thanks again, btw the headers you sent are look really good- worth the drive to Niagara falls to pick up
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
My (Dyno Don) headers would come loose often, sometimes the bolts fell off completely and began to leak, so Dyno Don got a special lock washer (I forget the part number) that he used on my headers. That solved the problem, they haven't leaked since. Probably a good idea to check them every so often anyway.
84z96L31vortec
Aug 20, 2017 12:16 AM
ambainb
Apr 25, 2016 09:21 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
