Hedman 68460
Old Jan 20, 2014 | 12:43 AM
sotodn1's Avatar
Car: 1986 Iroc-Z
Engine: 5.7
Hedman 68460
I bought a set of long tube headers from hedman and while I have searched the forums for installation tips one thing I didn't notice is whether or not others have had issues with the brake reservour and brake boost getting in the way on the drivers side. I have also heard about grinding down the A arm mount. Does anyone have any tips on how to make installation simpler/fast? Not sure where to start, Thanks!
Old Jan 20, 2014 | 11:21 AM
Guest
Guest
Posts: n/a
Re: Hedman 68460
Nothing happens to the brakes. Best thing to do is PRAY...you'll need it.
<-has LTs, NO motor jacking
Old Jan 20, 2014 | 01:03 PM
sotodn1's Avatar
Car: 1986 Iroc-Z
Engine: 5.7
Re: Hedman 68460
Sorry bud I didnt understand your post. What do you mean?
Old Jan 20, 2014 | 01:16 PM
Sleeper Z's Avatar
Car: 1987 Z28
Engine: 370hp 350
Transmission: 5 speed
Axle/Gears: G92 3:45 Posi
Re: Hedman 68460
I got headman headers specifically for the 3rd gen camaro and they dump at the bottom of the oil panand had a collector pipe made at a muffler shop. I had to lift the motor off the mounts by 3 or 4 inches to get them in, then lower the motor before bolting them on. A bit of a pain to install but no grinding or mods were required.
Old Jan 20, 2014 | 01:20 PM
sotodn1's Avatar
Car: 1986 Iroc-Z
Engine: 5.7
Nice! Yeah it says those hedman 68460 are for third gens. Sucks im gonna have to undo the motor mounts. Did you have to unbolt the tranny or do you think I can manage with those 3-4 inches with the tranny bolted up?
Old Jan 20, 2014 | 01:32 PM
Sleeper Z's Avatar
Car: 1987 Z28
Engine: 370hp 350
Re: Hedman 68460
I put a jack under the tranny and removed my cross member but left it connected. I lowered it slightly maybe 1 or 2 inches at the most just to get the angle to make sure the bell housing didn't hit when i raised it.
Old Jan 20, 2014 | 01:37 PM
sotodn1's Avatar
Car: 1986 Iroc-Z
Engine: 5.7
Hmmm sounds like its not too bad, but I think this is a project I wanna leave for the weekend
Old Jan 20, 2014 | 01:39 PM
sotodn1's Avatar
Car: 1986 Iroc-Z
Engine: 5.7
Sounds like thats the only way to slide them in. Don't understand how others claim they go in without interference.
Old Jan 20, 2014 | 01:43 PM
Sleeper Z's Avatar
Car: 1987 Z28
Engine: 370hp 350
Re: Hedman 68460
Well i would give it a good day with a buddy to do it. Also since your going to do this it would be a good idea for $40 or $50 to replace the motor and tranny mounts if they havent been done yet. I didnt and had my tranny mount go on me 2 weeks after and had to do it anyway again! Which really sucked!
Old Jan 20, 2014 | 01:45 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: Hedman 68460
you can get them in from the bottom, you need to trim the a-arm bracket, and if your motor mounts are old and sagging you will hvae issues with the drivers side header hitting the K-member
Old Jan 20, 2014 | 01:51 PM
sotodn1's Avatar
Car: 1986 Iroc-Z
Engine: 5.7
Darn. I just replaced the motor and silly me never changed the mounts. I guess I can try jacking the car up some more and trying to access from underneath, but lifting the motor seems like a fool proof way
Old Jan 20, 2014 | 01:52 PM
Sleeper Z's Avatar
Car: 1987 Z28
Engine: 370hp 350
Re: Hedman 68460
Well I would alow a good day with a buddy to do it but it's not that bad. However if your gonna go through the trouble it would be a good idea to spend the $40 or $50 to replace the motor and tranny mounts while it's apart, if they haven't been done. I didn't and my tranny mount went 2 weeks after I had it apart. Which sucked big time!
Old Jan 20, 2014 | 01:58 PM
Sleeper Z's Avatar
Car: 1987 Z28
Engine: 370hp 350
Re: Hedman 68460
Ya changing to mounts is accessable from underneath. bit of a pain but worth it. Lol!
Old Jan 20, 2014 | 02:03 PM
sotodn1's Avatar
Car: 1986 Iroc-Z
Engine: 5.7
Lol no i meant jacking the motor up to install the headers from underneath, not the motor mounts. Thats just *** backwards.
Old Jan 20, 2014 | 02:06 PM
Guest
Guest
Posts: n/a
Re: Hedman 68460
MY mounts are sagged
(you can even see the motor is sitting with a tilt, and my car has been in a BAD wreck...)
I didn't have to do any jacking or any large unbolting.
Old Jan 20, 2014 | 02:08 PM
Sleeper Z's Avatar
Car: 1987 Z28
Engine: 370hp 350
Re: Hedman 68460
Nice! but mine went in easy from the top!
Old Jan 20, 2014 | 02:19 PM
Sleeper Z's Avatar
Car: 1987 Z28
Engine: 370hp 350
Re: Hedman 68460
In my mind there's something wrong with cutting parts to get others in. Lifting the motor worked great for me.
Old Jan 20, 2014 | 02:24 PM
sotodn1's Avatar
Car: 1986 Iroc-Z
Engine: 5.7
Nice Im gonna try that then. Here are some pics showing the interference. Btw, how did you get tall valve covers to work?
Old Jan 20, 2014 | 03:01 PM
Sleeper Z's Avatar
Car: 1987 Z28
Engine: 370hp 350
Re: Hedman 68460
Well after looking at your pics they're not the same type of headers I have. Sorry! U may have to cut to get those in. Mine are short and dump quick. But i would still try to lift the motor and try from underneath before cutting anything.
Old Jan 20, 2014 | 03:12 PM
Sleeper Z's Avatar
Car: 1987 Z28
Engine: 370hp 350
Re: Hedman 68460
The tall valve covers are angle cut at the top. Came straight from chevy performance parts. I needed tall ones for the roller rockers to clear. They weren't cheap though.
Old Jan 20, 2014 | 04:37 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Hedman 68460
These are pretty easy to get on. Just trim the a-arm mount a little. The driver's header needs to be slightly bfh'd but not too bad. They go in easy from the bottom. I never unbolt either the crossmember OR the engine mounts when I do them. The trick is to have a ministarter, makes it much easier to get them in. I think one time I did them and I had to lower the tailshaft a little.
Old Jan 20, 2014 | 09:41 PM
sotodn1's Avatar
Car: 1986 Iroc-Z
Engine: 5.7
Hey thanks everyone for the quick responses. I think I now have a clearer idea of what I need to do! And Sleeper, weren't those valve covers like $200?
Old Jan 20, 2014 | 10:39 PM
Sleeper Z's Avatar
Car: 1987 Z28
Engine: 370hp 350
Re: Hedman 68460
Ya they were $350 Canadian so roughly that in US $... Lol We pay through the nose up here.
Old Jan 21, 2014 | 03:14 AM
sotodn1's Avatar
Car: 1986 Iroc-Z
Engine: 5.7
Re: Hedman 68460
Whew, I thought that's about right, Thought I saw those at a local pepboys. Think I will stick to the ones that were on my 305 lol. But hey thanks again to all you guys for the help I really appreciate it. I may have to keep in touch as I finish this thing, got a few more questions I might need answered and you guys seem plenty knowledgable.
Old Jan 23, 2014 | 12:49 PM
sotodn1's Avatar
Car: 1986 Iroc-Z
Engine: 5.7
Hey guys its me again, is this the bracket that I may have to cut down?
Old Feb 23, 2014 | 08:18 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Re: Hedman 68460
yes
Old Feb 27, 2014 | 12:27 AM
sotodn1's Avatar
Car: 1986 Iroc-Z
Engine: 5.7
Re: Hedman 68460
Thanks man!
Zell1luk
Sep 29, 2015 10:36 AM
italiano67
Sep 22, 2015 08:42 AM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
cstrobel65
Sep 16, 2015 11:54 AM
WickedBowtie
Sep 11, 2015 11:24 PM
