HELP! 1987 headers that fits with manual tranny?
Old Feb 16, 2014 | 02:00 AM
chad87sc's Avatar
Car: 1987 sport coupe camaro
Engine: 355
Transmission: 5 speed
I couple years ago I ordered hedman headers for my 87 camaro 5 speed.. It said they would fit and they didn't fit due to the bell housing for the manual trans. Anyway I had to Butcher the driver header to fit but now I'm ready for exhaust and can't use my driver header because I had to square the end to fit around the slave. Can anyone lead me in the direction to headers that actually fit with a 5 speed car?
Old Feb 16, 2014 | 07:02 AM
Re: HELP! 1987 headers that fits with manual tranny?
I've had Edelbrock TES and SLP on my car; both of those fit fine.
Old Feb 16, 2014 | 10:08 AM
chad87sc's Avatar
Engine: 355
I read these can be restrictive especially the tes? My engine is a 355 that's pretty healthy with a lumpy cam est. 400-450 hp. I'd like to keep with longtubes if that's possible. . Any other ideas?
Old Feb 16, 2014 | 12:49 PM
MrBrooks's Avatar
Car: '92 RS
Engine: 357ci
Transmission: G-Force t-5
Axle/Gears: 4.10 10bolt mini spool
Doug's D3321's
Hooker 2210's
Ed Quay
Stainless Works
All of those are options.............in order from least to most expensive
the Doug's are VERY similar to the Hooker........................ 1.75" primaries with 3" collectors
All will work with our slave cyl setup
Old Feb 16, 2014 | 03:32 PM
chad87sc's Avatar
Engine: 355
Originally Posted by MrBrooks
Doug's D3321's
Hooker 2210's
Ed Quay
Stainless Works
Thanks that was definitely helpful. I hate to sound cheap but are there any options under $400 out there?
Old Feb 16, 2014 | 07:48 PM
MrBrooks's Avatar
Car: '92 RS
Engine: 357ci
Have seen some OBX units on ebay for about that...........2.5" collecors tho
they are usualy in that price range...............chinese made stainless units...............seen good reports here as well as horror stories.............not sure about clutch clearance
Old Feb 16, 2014 | 09:25 PM
alltwocents's Avatar
Car: 86 T/A
https://sdparts.com/details/doug-tho...aders/dhcd3321
554.99 Jegs will price match
Old Feb 16, 2014 | 10:38 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
As far as I know almost every header on the market will work with 5 speeds except the Hedman long tubes...
Old Feb 18, 2014 | 04:57 AM
splitty's Avatar
Car: 82 Z28
Engine: 370 ci.
Transmission: M 20 4 speed
Axle/Gears: stock open 3.43
Has anyone tried the 3321's. they are cheaper than the hookers by a lot. but if they don't fit they aren't worth 10 cents.
Old Feb 18, 2014 | 04:59 AM
splitty's Avatar
Car: 82 Z28
Engine: 370 ci.
I saw the 3321's for 434.00 without the ceramic coating if that helps.
Old Feb 19, 2014 | 11:48 AM
MrBrooks's Avatar
Car: '92 RS
Engine: 357ci
I heared some time ago that Dougs had stolen a designer away from Hooker..................he happened to be the designer of tbe 2210...............I wouls think the fit would be as good if not better than the Hooker......
Have see nothing but good comments on the Doug's units..........
Old Feb 19, 2014 | 10:38 PM
splitty's Avatar
Car: 82 Z28
Engine: 370 ci.
Thanks Mr Brooks.
Old Feb 22, 2014 | 08:26 AM
Dueling73s's Avatar
Car: 73RS, 85 Iroc, 11 GT
Engine: 383FI, 406 FI, 5.0
Transmission: TKX, TKO600
Axle/Gears: 10 Bolt 3.73s, Strange 12 bolt 3.73
I can testify that the Hookers fit well. If you are not planning on be lowered too much they would be a good header. I actually have a coated set that have never been run that I would be willing to part with. The only reason I decided not to use them is that I am lowered about 3 inches and just not enough ground clearance. I now have a set of the Hawks Stainless works. These give me great ground clearance but did not clear the slave set-up. I ended up getting rid of the slave and bracket and went with a dydraulic TO bearing.
Old Feb 22, 2014 | 02:17 PM
Car: 86 T/A
How much are you asking for the Hooker headers
Old Feb 22, 2014 | 07:37 PM
Dueling73s's Avatar
They are the Ceramic Coated 2210's never been run, how about $400 plus shipping?
1992 Trans Am
May 10, 2023 07:19 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
camaro11j
Sep 19, 2018 08:49 AM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
drathaar907
Aug 6, 2015 04:20 PM
