Post pic of how you route your wires with headers
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
I am running my drivers side wires over the valve covers, the passenger side I am running down the back of the motor and under the headers. However, there isn't much room between the header/starter/block to run the 4 wires. How is everyone else doing this?
Car: 87 Camaro Z/28
Engine: 327 SBC, 495/481 lift, Dem 625cfm
Transmission: B&M TH350 Stage 2
Axle/Gears: 3.90
Re: Post pic of how you route your wires with headers
I have spark plug wire looms that route the wires over the headers, right next to the valve covers, this particular loom set bolts on using the valve cover bolt. I will post some pictures for you this afternoon.
Car: 1986 Pontiac Firebird
Engine: 383 SBC
Axle/Gears: Hawks 8.8 with 4.10’s
Did your looms require you to make custom length wires?
Car: 87 Camaro Z/28
Axle/Gears: 3.90
Yes, the wires I bought had to be put together anyway. The are MSD's. The custom lengths make it look nice. Pics below.
eightsixseven
Dec 16, 2024 01:50 PM
