hedman headers hit frame on both sides
Old Jun 25, 2014 | 11:50 AM
joneepee's Avatar
Hi guys I just installed a set of hedman headers 68460 long tubes on my 84 z28 they hit the frame on both sides and also the lower control arm on driver side any suggestions on how to solve this problem thanks for any help you can give
Old Jun 25, 2014 | 01:01 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: hedman headers hit frame on both sides
I dont know how it's hitting the frame on the passenger side, mine doesn't. The driver's side needs a BFH'ing to the primaries and a small part of the control arm perch trimmed off.
Old Jun 25, 2014 | 01:39 PM
joneepee's Avatar
Hi thanks for replying I was definitely thinking of BMFHin it .I was also reading on a different thread changing motor mounts will help
Old Jul 29, 2014 | 10:07 PM
transaero's Avatar
Car: 1987 Trans Am GTA
Engine: Warmed over 350 TPI
Transmission: 700r4 soon to be t56
I'm no expert on exhaust, but from what I've read, maybe your motor mounts are worn out. If they are, when you replace them, it should slightly raise the engine enough for the headers to fit.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Wesly_66
Aug 26, 2015 09:55 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
