full length header exhaust
Old Jul 23, 2014 | 04:12 PM
408supert10's Avatar
I have a 83 Z with full length headers...want to do true duel exhaust...anyone have tips or know of ready made setups?
Old Jul 23, 2014 | 07:42 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
Re: full length header exhaust
it will be a custom set-up. no pre made ones that i am aware of. you will have 2 choices, run both pipes along factory routing or run the pipes done along the drive shaft
Old Jul 24, 2014 | 07:02 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
^what he said^
I have full length headers and true duals, (2.5"). Here is my set up. Fairly simple and cheap with decent ground clearance. However, I'm running a 28" rear tire so that helps alot. I included a side shot to show.
Attached Thumbnails full length header exhaust-rsz_sd531740.jpg   full length header exhaust-rsz_sd531745.jpg   full length header exhaust-2.jpg
Old Jul 24, 2014 | 08:01 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
while not pretty looking, i managed to run true dual 2.5" pipes up and over the rear in the stock location.
take your time, look through lots of dual exhaust pics/threads/posts on here. a well thought out plan is a good thing.
Old Jul 24, 2014 | 01:10 PM
Look at the top of this section in the stickies, there is a pic collection of dual exhaust
Old Jul 30, 2014 | 09:14 AM
DrkHwk's Avatar
Car: 02 Hawk
Engine: 427
Axle/Gears: 3:42
I was just reading that kooks has a dual setup for 4th gen. might be able to adapt it?
DrkHwk's Avatar
Car: 02 Hawk
Engine: 427
Axle/Gears: 3:42
It's very expensive tho.
Old Jul 30, 2014 | 09:19 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Search
Old Jul 30, 2014 | 09:48 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Willie has a dual exhaust set up that runs along the factory single routing. Pretty sweet set up. Pictures are in the dual exhaust collection in the stickies.
LT1Formula
20
Nov 14, 2015 12:02 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
Dialed_In
Aug 20, 2015 01:45 PM
mustangman65_79
Aug 7, 2015 09:55 PM
