Tri-y long tube vs long tube
Old Jun 27, 2014 | 03:55 PM
2slow5.0's Avatar
Car: 91 Formula
Engine: 5.0 tpi slow
Transmission: WC t-5
I'm looking for some input on my exhaust options. Engine is a 358ci with super ram and fastburn heads. Right now I have slp tri-y's (on the original engine). After the swap I'm contemplating using hooker super comps or my try-y's. if I stay with the tri-y's I'm gonna do away with SLP y pipe and make my own secondary's that run on each side of the trans then reconnect pehind the trans. I may even step it up to a larger pipe. Never seen a setup like this. I think it would solve many clearance issues. I just don't know if the would flow what the super comps do.
Old Jun 27, 2014 | 05:29 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Tri-y long tube vs long tube
A properly designed tri y aka 4-2-1 header will match or outperform a long tube header at peak hp but the main advantage is generally more low to mid range power increases. More area under the curve.
If you run the right pipe size and lengths you'll have a good design. Primaries could be 1 5/8 and first Y connect to 1.875. Then connect to 2.5 collectors at the second.
I built a set of 1.75 to 2" to 2.5" tri y's for my ls1 and run faster than old pacesetter longtubes. But the dual 2.5 now vs single 3" on the longtubes may be a reason for the difference
Old Jun 27, 2014 | 05:32 PM
1991sleeper's Avatar
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
Get the hookers and sell me the triy for my 305 build lol
91' bird 305 TBI T-5, trick flow 175 cc heads, 4.10 gears, lots of suspension upgrades......... 24mpg @ 2300rpm hwy 65mph ........ 8.63@ 85mph 1/8th on street tires... 8.000's soon
Old Jun 27, 2014 | 05:48 PM
2slow5.0's Avatar
Car: 91 Formula
These are 1 3/4" primaries, I was gonna step em to 1 7/8 on the secondaries to a 3" y pipe.
It'll all be fabricated so clearance can be built in. Idk on the pipe/collector length though
Old Jun 27, 2014 | 05:53 PM
2slow5.0's Avatar
Car: 91 Formula
I'm gonna hang on to these. I do have a 1 5/8" set with dual cat secondary pipes I could prolly part with though
Old Jun 27, 2014 | 07:54 PM
Car: 1991 firebird
Axle/Gears: 4.10
What u want for em ? Pics ?
z 28 jari
Sep 14, 2021 10:03 PM
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
cstrobel65
Sep 16, 2015 11:54 AM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
