2 Bolt Flange?
Old Jul 23, 2014 | 11:43 PM
keaton_chad's Avatar
Car: 85 z28
2 Bolt Flange?
I just got a new cat back exhaust system from dynomax. it was the dynomax ultra flows. it came with a 2 bolt round flange but my car comes stock with a 4 bolt square flange. This means i can not bolt those two flange brackets together. does anyone have and ideal on what i could do and to solve my problem. thanks
Old Jul 23, 2014 | 11:59 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: 2 Bolt Flange?
I believe you may be mistaken. I apologize if I'm wrong. The 4 bot flange on the outlet of the catalytic converter is correct, and one if not both sets may line up with the two of the cat-back exhaust pipe from Dynomax.
A picture of my 4 bolt #93441 Magnaflow Direct-fit Catalytic Converter bolted to my #16829 Magnaflow Cat-Back Exhaust.
Hope this helps.
Old Jul 24, 2014 | 12:45 AM
Car: 85 z28
Re: 2 Bolt Flange?
My 4 bolt flange has a bolt in each corner. i don't see how the two bolt flange would hook up with the 4 bolt one unless it bolted up with the two corner bolts. i will post a picture tomorrow to give you guys a better look at what i'm dealing with.
Old Jul 24, 2014 | 01:00 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Re: 2 Bolt Flange?
Correct, it will use two adjacent bolt holes to line it up, but as you can see from my picture, you can get the 4bolt flange to be parallel with the ground. It's the 2bolt flange on the cat-back that will be angled. No leaks.
Old Jul 24, 2014 | 07:44 AM
Car: 85 z28
Re: 2 Bolt Flange?
Here are the pics. i see how you would use the adjacent bolts on the 4 bolt flange, but to me the two adjacent bolts look way farther apart then the span of the two bolts on the 2 bolt flange. do they just look father apart then what they really are. should the two flanges line up. if not what can i do to fix this.
Old Jul 24, 2014 | 10:22 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: 2 Bolt Flange?
You need to get a 4-bolt flange and weld it to your catback pipe.
The 4-bolt is flat, the 2-bolt is a ball & socket arrangement.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
customblackbird
Oct 1, 2015 04:30 PM
Numbah-1
Sep 12, 2015 08:57 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
