Dual exhaust question
Old Jul 26, 2014 | 09:15 AM
nateg's Avatar
Car: 89 Camaro Iroc-Z
Engine: 383 Stroker
Axle/Gears: 3:27
I have a 1989 Iroc and was wondering if it's possible to run true duals off of hooker long tubes. I have a bunch of 3in piping laying around just looking at a huge clearance issue and possibly not working at all. Any thoughts?
Just fyi I have the hooker long tubes already on the engine and this is why im starting to see some clearance and mounting issues.
Old Jul 26, 2014 | 10:14 AM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
Re: Dual exhaust question
Yes you can. Many have done it including me. There is a sticky on this page with plenty of pics. Your ground clearance will go down. You have 2 options, either run the pipes along the stock routing or down the middle by the drive shaft tunnel.
Old Jul 26, 2014 | 10:51 AM
nateg's Avatar
Engine: 383 Stroker
Axle/Gears: 3:27
I'm definitely looking at running it down along the drive shaft tunnel, however right next to the transmission how did you run the pipes off the headers?
Old Jul 26, 2014 | 11:27 AM
i have hedman headers but hookers should be similar. i used these s-extensions to get it under the cross member...http://www.summitracing.com/parts/hed-18804/overview/
they are universal so they should still work just get the size you need. let me get some pics loaded up and i will show you how mine looks.
Old Jul 26, 2014 | 01:27 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
If you are going to run 3" duals I would suggest the founder panhard relocation kit. It will make your life much easier.
http://www.foundersperformance.com/p...elocation-kit/
Old Jul 26, 2014 | 02:23 PM
here are some pics...
[IMG], on Flickr[/IMG]
Old Jul 26, 2014 | 02:26 PM
better pic showing from the rear....
Old Jul 27, 2014 | 12:38 PM
nateg's Avatar
Engine: 383 Stroker
Axle/Gears: 3:27
Would a flexible 3 inch pipe that I am looking at be a possibility? I don't know if anyone knows the integrity of the piping or had a run in with it before.
Old Jul 27, 2014 | 02:09 PM
SRKLEGIN's Avatar
Car: 1986 IROC-Z
Engine: 90-95 ZZ4 Crate 350 TPI
Transmission: 700R4 4spd Automatic
Axle/Gears: 3:73
Nice exhaust set-up. was always intrigued about putting headers on my 1986. The only question I would have is the o2 , cat...since I am slaved to emissions and safety. does look like it runs a bit low...in Utah we have these humongus dips off the street into parking lots and such...whats the hang distance related to stock?
Old Jul 27, 2014 | 02:14 PM
SRKLEGIN's Avatar
Car: 1986 IROC-Z
Axle/Gears: 3:73
Can you give me some shots of your engine (headers)
i would say i lost 2.5-3 inches of ground clearance. you need to be careful where you drive lol.
Old Jul 27, 2014 | 02:23 PM
i personally dont like the flex tubing. i see it as a band aid, not a permanent fix.
yeah give me a couple minutes.
Old Jul 27, 2014 | 03:05 PM
here you go...
Old Jul 27, 2014 | 03:26 PM
SRKLEGIN's Avatar
Car: 1986 IROC-Z
Axle/Gears: 3:73
WOW... That was quick!!! Thanks...
Old Jul 27, 2014 | 03:29 PM
SRKLEGIN's Avatar
Car: 1986 IROC-Z
Axle/Gears: 3:73
I have to get some better shots of my exhaust system, but still am a bit bewildered on how I am going to retrofit the emissions stuff. doesn't look promising.
Attached Thumbnails Dual exhaust question-uvu-2.jpg   Dual exhaust question-p1010005.jpg
Old Jul 27, 2014 | 03:30 PM
SRKLEGIN's Avatar
Car: 1986 IROC-Z
Axle/Gears: 3:73
K.
Old Jul 27, 2014 | 03:50 PM
yeah i am lucking and dont have to mess with any emissions or inspections. there is no way at all i would pass lol.
Old Aug 13, 2014 | 03:57 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
It is also possible to run dual 2.5" or 3" over the axle, following close to the stock routing. Midias has linked to a panhard bar relocation kit in post #5. Something like that kit is necessary for dual 3". Not needed for dual 2.5". The pipe routing has to be pretty exact to clear dual 3s this way, but I have seen it done. I am going to be doing my own dual 3" over the axle this winter.
There is a sticky on this forum showing pics of a dual 2.5" system. The car owner is Willie.
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
beastin91rs
Oct 9, 2015 07:38 AM
Dialed_In
Aug 20, 2015 01:45 PM
redmaroz
Aug 16, 2015 11:40 PM
