High Flow Cat or No Cat?
Old Aug 6, 2014 | 07:12 AM
ThirdGenKen's Avatar
Car: 1987 Chevrolet Camaro Iroc Z28
Engine: 383 Stroker supercharged.
Transmission: 5 speed manual transmission
Axle/Gears: 3.45 posi rear
I am going to be getting a custom exhaust built for my 87 Iroc. I am going to go with a single 3 inch into a hooker aero chamber muffler with two 2 1/2 tailpipes. Should I go with a high flow cat or just delete the cat completely?
What are your experiences and opinions on this?
Old Aug 6, 2014 | 10:00 AM
MrBrooks's Avatar
Car: '92 RS
Engine: 357ci
Transmission: G-Force t-5
Axle/Gears: 4.10 10bolt mini spool
Re: High Flow Cat or No Cat?
First thing to consider is your displacement..........~6.3L and you are boosted so actual amount of gases exiting the engine will be 6.3L plus boost. So, that being said, you will be at the ragged edge of the capacity for a single 3' Hi-Flo Cat(most are rated at around 6L). thats before you put any boost in the motor. So....unless you are able to run one off of EACH bank of the motor......it will be a bottleneck.
Second thing to consider is SMOG ****'s...........if you have no inspections where you live you are best off to go without.
Personally......I am going to go with one at each collector when I get the 427sb in......just to make a point.......I personally believe that the power loss will be so small that I may as well make the effort to save some fresh air for my Grankiz Grankidz.....you know what i mean????
Old Aug 6, 2014 | 02:18 PM
I have inspections where I live, but I work at a shop, so someone there will pass it for me. I think I am going to go with no cat. Is a single 3 inch plenty of flow for a 383 stroker with boost or should I go 4 inch exhaust?
Old Aug 6, 2014 | 02:35 PM
hrspwr's Avatar
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
I have dual magnaflows and they have not hurt any performance, at leas that I can tell. Worth it in my opinion.
Old Aug 6, 2014 | 02:36 PM
Dual magnaflow cats?
Old Aug 6, 2014 | 02:56 PM
hrspwr's Avatar
Car: 86 IROC
Axle/Gears: BW 3.27
Yes Dual.
The issue is that you have not said what headers or routing you will be doing with the custom exhaust. I have shorties that go into 3" collectors/ypipe with dual cats into a single 3" flowmaster. I am using the stock routing. Cats I used are these:
http://www.magnaflow.com/02catalytic...niversal=59959
Old Aug 6, 2014 | 03:00 PM
I have Edelbrock shorty headers on it now. I think Mrbrooks had a good point, with mine being supercharged and a 383 stroker, I might be better off without a cat.
Old Aug 6, 2014 | 03:06 PM
1991sleeper's Avatar
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
3.5 or bigger mandrel bent
Or dual 2.5
Old Aug 6, 2014 | 03:08 PM
hrspwr's Avatar
Car: 86 IROC
Axle/Gears: BW 3.27
I agree to a point. What is the loss going to be? 10hp?
I think the shorties are more of a restriction than dual cats will be. Unless they are 1 3/4, but I dont think Edelbrock makes them that large.
Old Aug 6, 2014 | 08:13 PM
khulsebus's Avatar
Car: '89 Camaro
Transmission: 4L65/70E
Axle/Gears: 9 Inch, 3.70 gears
Use the high flow cats. Car Craft did an article a few years ago, when Frieburger was still the editor and the logo was "Do It Yourself Performance" or something to that effect. Either way, their dyno mule lost 1 hp to dual high flow cats.
Old Aug 9, 2014 | 11:38 AM
MrBrooks's Avatar
Car: '92 RS
Engine: 357ci
Your best bet all the way around will be to send a PM to DYNO DON. Ask him what he can do that will be adequate for your application. He is making the ONLY shorty header i would even consider running on a blown stroker. You will have to put out a little more $$ for his pipes..........but in the end you cant beat them in the world of shorties.......I would think he can most likely do something custom to in the Y-pipe to make it a dual cat set-up that will be adequate......
Old Aug 10, 2014 | 01:58 PM
Thanks for the input everyone. I will post pics once I get it done.
Old Aug 10, 2014 | 01:59 PM
twowwwerf's Avatar
Or dual 2.5
Agreed. Single 3" is certainly the bare minimum for this kind of displacement + FI
Old Aug 10, 2014 | 02:11 PM
Do they make headers with 3.5 Y-pipes or would I just have to get an adaptor? Will full size headers fit in a thirdgen camaro?
Old Aug 12, 2014 | 12:35 AM
MrBrooks's Avatar
Car: '92 RS
Engine: 357ci
http://www.summitracing.com/parts/do...t/model/camaro
or
http://www.edquay.com/camaro/index.html
best option will be the Ed Quay.......1 7/8 primaries at your displacement and blown the huge tube option will be best.....lol
will be a FULL custom Y-pipe to I and out the back....... 3"Y to merge and 4" out the back thru a Hooker Max Flow........ would be the best way to go....IMHO....
http://www.jegs.com/i/Hooker+Headers/520/21609/10002/-1
http://www.jegs.com/i/Flowmaster/389...oductId=744773
Old Aug 12, 2014 | 06:27 PM
Ok. Thanks.
mud runner
Nov 2, 2015 07:30 PM
corey8084
Sep 17, 2015 02:56 PM
Stroopwafel
Sep 11, 2015 06:38 AM
89fast5oh
Sep 8, 2015 09:55 AM
Stryker412
Sep 7, 2015 09:11 AM
