Full Exhaust Help
Old Feb 3, 2015 | 04:33 PM
TreDeClaw's Avatar
Car: 1983 TA WS6
Engine: 357 (5.7L)
Full Exhaust Help
I am replacing my whole exhaust. I have stock exhaust currently on my 83 trans am.
Do vortecs have different bolt holes for headers then a stock trans am head?
I am also wondering if any of you had tried these products.
http://www.summitracing.com/parts/sum-g9005
http://www.summitracing.com/parts/big-11102flt
http://www.summitracing.com/parts/big-11102yflt
Or these headers but I cant find a Y-Pipe to go with it
I also don't know how to fill the hole where I am going to get rid of my cat.
Is is possible to put a glass pack where the cat was and then run straight pipes all the way back?
I know 3 In. is better but it seems to double in price.
Old Feb 3, 2015 | 11:36 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Full Exhaust Help
I don't know about the Vortecs' but this is for your stock heads.
This is the style Y pipe you want. Not that T connection that's as bad as stock.
These headers and Y are designed to fit together and come up in the search using your car.
= http://www.summitracing.com/cart
Old Feb 4, 2015 | 02:35 PM
TreDeClaw's Avatar
Car: 1983 TA WS6
Engine: 357 (5.7L)
There is nothing in your link... I still need help.
Old Feb 4, 2015 | 03:12 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
You can bolt regular headers to vortec heads no problem. I bolted hooker 2460s to my vortec heads without issue and the summit house brand headers.
Old Feb 4, 2015 | 07:48 PM
Engine: TBI,5.0
Link to Y = http://www.summitracing.com/parts/hok-16767hkr
Link to headers = http://www.summitracing.com/parts/hok-2460hkr
Old Feb 4, 2015 | 08:43 PM
TreDeClaw's Avatar
Car: 1983 TA WS6
Engine: 357 (5.7L)
Those both look like great products. I saw that Y-pipe but I had not found headers in my budget. Thanks.
With that said what is the best combo to go with those headers and ypipe (cat back/glasspack) and how could I potentially delete the Cat?
Old Feb 5, 2015 | 09:54 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
The first question you have to answer, is do you need emissions?
Only then can you decide if you want to delete the cat.
The ones Ron listed are good. If you need emissions, here are these: They come with a Y-pipe so there is no issue with bolt up but might be a little more expensive.
I highly recommend that, if you can afford it, get them Jet-Hot coated. You'll never regret it.
Hooker 2055 Shorties
Old Feb 5, 2015 | 03:09 PM
TreDeClaw's Avatar
Car: 1983 TA WS6
Engine: 357 (5.7L)
I live in MN so I don't have any emissions requirement
Old Feb 5, 2015 | 03:37 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Hey hey! I'm from there. St. Cloud area. Moving back next fall it looks like as well. Where about do you live?
For the car, then I'd get the 2460's that Ron mentioned and the y-pipe that goes with it ONLY if budget is your concern.
If you can afford it in any way, maybe talk to Dyno Don, but Dyno don and Hooker 2055's, both come with y-pipes so are a more expensive compared to just the headers, are specifically built for our cars. The 2460's are more generic for "Chevy/Pontiac" and may not fit as nicely.
Old Feb 5, 2015 | 04:34 PM
TreDeClaw's Avatar
Car: 1983 TA WS6
Engine: 357 (5.7L)
Woodberry, Oakdale, Maplewood area.
So where should I begin cat - back then?
Old Feb 5, 2015 | 05:41 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Headers and y-pipe won't do much if you don't do the whole exhaust. If you drive your car at all in the winter, you'll need a stainless steel set up. Alumenized just gets tore up. Magnaflow makes a pretty good set up, but it's more of a mellow sound, so depending on what you are looking for regarding "loudness". either way, 3", stainless steel. Aerochamber muffler's are pretty good and are some of the best flowing mufflers out there.
Old Feb 5, 2015 | 06:03 PM
TreDeClaw's Avatar
Car: 1983 TA WS6
Engine: 357 (5.7L)
Well I have the headers and Y pipe chosen which is about $500. My budget is $1000 I would like to keep it around $800.
I like flowmaster but I don't like the fact it outlets two ports from the muffler. what are aerochamber mufflers? Straight pipes almost? My thought is to get a glass pack and then split pipes after that. Not sure how that would work.
I'm looking for loud.
Also any good cheap cats in my budget?
Old Feb 5, 2015 | 06:14 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Here is my stuff, it doesn't get any better than this (but like he said a bit pricey)
Old Feb 5, 2015 | 06:20 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Dyno Don has some great stuff!
This one: Hooker Aerochamber
These cars were designed for a 3" single in, dual out cross-flow muffler. YOu can do single-in, singel-out mufflers, or just one muffler, but it's going to be loud. Also, if you ask me, only one pipe coming out the back of our cars looks wrong. If you want loud, flowmaster 40 series is pretty loud. I personally don't like it. I can't carry on a conversation with my wife or kids when just cruising.
If you go into the exhaust section, you can search for exhaust examples. There are lots of sound bites of the various exhaust people have.
Old Feb 5, 2015 | 06:21 PM
Ozz1967's Avatar
Car: 1984 Trans Am
When next I buy headers, them's it! Hmm, I can sell my hookers... lol Stop it Dyno Don! You're giving me bad ideas!
Old Feb 5, 2015 | 06:23 PM
TreDeClaw's Avatar
Car: 1983 TA WS6
Engine: 357 (5.7L)
Are you selling these?
I think I am going with the Hooker competition headers linked in a previous post.
Old Feb 5, 2015 | 11:10 PM
Ozz1967's Avatar
Car: 1984 Trans Am
That's Dyno Don posting himself. He owns the company that sells them.
customblackbird
Aug 15, 2021 10:16 PM
Dyno Don
Jan 24, 2016 08:24 AM
92projectcamaro
Jan 18, 2016 08:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
greenyone
Sep 2, 2015 03:39 PM
