heat riser valve
Old Feb 1, 2015 | 10:59 AM
itsdeenoo's Avatar
Car: anything with wheels
Engine: 327
Transmission: t5
Axle/Gears: ford 8.8 4.11
heat riser valve
here is a pic of my heat riser valve that is unhooked no rod, no vacuum ,
in the pic the lever is all the way to the forward ????????? does this mean its closed or open thx
Old Feb 1, 2015 | 11:44 AM
Re: heat riser valve
I can hardly even tell what's in that pic, let alone what position anything is in... looks like it was taken with an Apple product...
However all that may be, if the lever thing is pointing somewhat downward from level, then it's open. If it's pointed upwards, it's frozen closed. The weight on the end of it opens it when the vacuum from the thermal vacuum valve goes away. Not sure about "rod".
Why not just pop it off and see?
Old Feb 1, 2015 | 12:36 PM
itsdeenoo's Avatar
Engine: 327
Transmission: t5
the lever is to the right and moves freely to the left (rod from vacuum pump is unhooked just wanted to know which was open position left or right for open
it is circled ...it is on the right side atm is this open or closed ?
Old Feb 1, 2015 | 12:58 PM
itsdeenoo's Avatar
Engine: 327
Transmission: t5
Old Feb 1, 2015 | 01:02 PM
That's just a terrible pic. I don't think "blowing up" will help it... kinda like, if you've got audio that's all distorted or muffled or sounds like mud, turning it up louder prolly won't make it sound any better...
In any case, when the weight falls down (or of it's the kind that doesn't have a weight, when the attachment point on the lever is downward as far as it will go) it's open.
The valve itself is asymmetrical. (and besides that, it's not the same on both sides either) It's MUCH larger on the "half" (actually more than half) on the side of the shaft that pressure against it would tend to open it, and MUCH smaller than half of its area on the side that pressure would tend to close it. If it's free to move, the pressure of the exh gas will tend to force and hold it open.
Pop it off and look at it.
Old Feb 1, 2015 | 01:06 PM
itsdeenoo's Avatar
Engine: 327
Transmission: t5
Old Feb 1, 2015 | 02:08 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
When vacuum is applied to the vacuum diaphragm, it pulls the rod which opens the heat riser valve.
Hopefully, this helps.
Old Feb 1, 2015 | 05:18 PM
itsdeenoo's Avatar
Engine: 327
Transmission: t5
here is a pic of one off a car and little tab is to the right so mine is open atm with no vacuum applied to it
Old Feb 2, 2015 | 06:19 AM
itsdeenoo's Avatar
Engine: 327
Transmission: t5
any replies?on my last post ?
Old Feb 2, 2015 | 06:17 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
In the time it's taken you to take photos, attach them to a post and then wait for a reply, you could have jacked up the car, dropped the y-pipe and determined if the heat riser valve was stuck open or closed.
Just saying.....
Old Feb 6, 2015 | 01:00 PM
joeld's Avatar
Car: 1986 Firebird, 1989 Vette, 1995 GP
With no vacuum applied, the valve is in the open position. In the open position, the pivot pin where the rod goes to should be facing the firewall. In your picture this looks to be open.
Joel
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
ccop
Convertibles
Sep 14, 2015 04:13 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
