Resetting the ECM ?
Old Jun 14, 2015 | 03:00 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Resetting the ECM ?
Should I reset the ECM after a CAT change. (disconnect the negative battery cable for 5 minutes.)
And what would be the re lean cycle ? How should I drive the car ?
I have a SMOG test in 7 days.
Old Jun 14, 2015 | 10:35 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Resetting the ECM ?
I wouldn't bother doing anything. It depends on what state of tune your engine is in but a new converter should bring the measured numbers down to almost nothing.
IMO, you need to make sure you're engine isn't slowly poisoning the new converter or you're going to be replacing it again in a few years.
When I replaced the converter on my old Acura Legend I drove it over to the inspection station immediately after I bolted it on (2.1 miles). No freeway driving, no tank additives, no tune up, no oil change....nothing.
Before:
After:
This is a stock engine with 437,835 miles on it. Yes, it's most likely poisoning the converter with blow by. The before converter is only 5 years old with 40k miles on it and it's already getting weak.
BTW, who the heck drives a car at a constant 15MPH??? Bogus test IMO.
Good luck and post up your before and after numbers when you get your certificate.
Old Jun 15, 2015 | 01:02 AM
Engine: TBI,5.0
Thanks for the reply.
The car went through a really rough time not long ago.
I believe that's what did the CAT in. It was a 9 year old Magnaflow.
The tune now is like night and day.The adjustments I have made now that the problem has been fixed is allowing it to run as I believe it should. Timing is dead on and min. Idle speed is also dead on so as long as the Thermac Switch is not causing a vacuum leak its all set taking that air flow into consideration.
Hopefully it's enough.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
Ed1LE
Sep 30, 2018 09:14 AM
okfoz
Oct 13, 2015 02:19 PM
Jlanz55
Sep 29, 2015 08:55 AM
