Help me find the pair!
Car: 1988 IROC-Z/G92
Engine: 5.0
Axle/Gears: BW 3.45 Eaton Truetrac
Looking at maybe getting this exhaust
If I were to do that, which headers would work and fit up to it? And where could I get a matching y-pipe?
Re: Help me find the pair!
Since that exhaust is stock configuration, any headers that would bolt up to a stock exhaust, would bolt up to it.
I'd suggest checking Dyno Don's. With the Y-pipe.
Car: 1991 Firebird Formula
Engine: 5.7L TPI
I just got that system and will be mocking it up this weekend. I'm going with Dyno Don 1 3/4" headers, and matching single cat y-pipe. I also went with the Magnaflow 3" cat. The main question is what sort of headers and power are you expecting? Different headers put the collectors in different places (I think?), so choose the y-pipe based on what headers you get. Note that the Dyno Don Y pipe requires some welding, so don't expect something that is just a direct bolt on. If you're interested I can post up some more information after I've test fit everything this weekend.
85@IRocZ
21
May 17, 2016 08:03 PM
89newfun
May 1, 2016 08:11 PM
Iroc z28 man
Apr 18, 2016 11:53 AM
