Old May 7, 2016 | 09:04 AM
Foosefan's Avatar
Car: 1992 z28 convert
Engine: 5.0
Axle/Gears: 342 posi
I just had a Magnaflow 16829 catback installed on my 1992 Camaro Z28 convertible. I am getting headaches when I drive it now. Is it possible the pipes do not stick out far enough from the body and the exhaust is coming back over the car and into the inside when the roof is off? Any other ideas? I would hate to cut the pipes and extend them after buy a system designed for the car.
Old May 7, 2016 | 11:55 AM
gt4373's Avatar
Transmission: 5-Speed Manual
Re: Exhaust
[QUOTEI just had a Magnaflow 16829 catback installed on my 1992 Camaro Z28 convertible. I am getting headaches when I drive it now. Is it possible the pipes do not stick out far enough from the body and the exhaust is coming back over the car and into the inside when the roof is off? Any other ideas? I would hate to cut the pipes and extend them after buy a system designed for the car.[/QUOTE]
No,Those Stick Out Farther Than The Stock One's,How Loud Is The Magnaflow Maybe It's Giving You Headaches.
Old May 7, 2016 | 01:49 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Re: Exhaust
I agree, you've got some other problem. Throw a high quality CO detector in the car (cheap ones don't react fast enough) and then see what the level is if you really think it's exhaust fumes. Any place that can test emissions, can also smoke test the exhaust and show you all the leaks it has. Like this guy does:
Old May 7, 2016 | 09:30 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Exhaust
How is your trunk seal?
A leak in that or a trunk not fully closed can let in all sorts of gasses
Old May 7, 2016 | 09:54 PM
Foosefan's Avatar
Engine: 5.0
Re: Exhaust
Thanks for the idea of the smoke tester. I had the O2 senser replaced a week after the new exhaust was installed.
Old May 7, 2016 | 09:56 PM
Foosefan's Avatar
Engine: 5.0
Re: Exhaust
I will check into it. We had no problems with the stock exhaust.
Old May 7, 2016 | 09:58 PM
Foosefan's Avatar
Engine: 5.0
Re: Exhaust
The Magnaflow sounds great. Suits the car deep and throaty but not too loud.
Old May 9, 2016 | 09:49 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Exhaust
My pipes are cut back a lot and there are no fume problems.
Old May 10, 2016 | 06:06 AM
Foosefan's Avatar
Engine: 5.0
Re: Exhaust
Thanks for the reply. Since changing the O2 sensor all is good.
Old May 13, 2016 | 05:35 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Exhaust
Be cautious with those big tailpipes right below the bumper. I had some tips like that years ago that scraped when I was just getting off a decline or getting on an incline. The Camaro I bought to restore had tips like this too and in the bumper right above each tip there was a slight oval indentation. Whoever had the car before me had the same issue.
SpectroRacing
31
Sep 18, 2020 12:30 AM
Bowtieman1970
Aug 17, 2016 02:50 AM
edpontiac91
Apr 1, 2016 01:25 PM
89 formula TPI
Mar 28, 2016 08:01 AM
87cam305
Mar 17, 2016 11:27 AM
