Cat removal
Old Mar 11, 2017 | 09:53 PM
Harleyquinn's Avatar
Cat removal
Just bought my first 86 ( Harley), and am looking to redo the muffler/exhaust. Im trying to stick with that old school classic rumble.
Any suggestions?
Old Mar 11, 2017 | 11:52 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: Cat removal
no emissions here, so everything is fair game. i'd start with headers first. then work your way back.
Old Mar 12, 2017 | 12:23 AM
Drew's Avatar
Re: Cat removal
Usually just squirt em with a spray bottle of water. Cats hate that. Couple squirts and they'll get the hint.
Old Mar 12, 2017 | 04:21 AM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
Re: Cat removal
Old Mar 12, 2017 | 12:44 PM
Re: Cat removal
👐👏🙌 I admire your humor, I tried that and she ran with her tail between her legs. Any other fatherly advice youd like to give?
Old Mar 12, 2017 | 01:55 PM
Drew's Avatar
Re: Cat removal
Unless the cat is faulty, I'd probably leave it alone. You haven't told us which engine your car has, but generally aside from the early cars and the V6, the cat isn't all that terrible. You won't gain as much in sound quality by gutting or deleting the cat as you would from a good muffler. If you want a little power boost in addition to sound, a good cat-back exhaust is the way to go. If you don't mind the install head aches, headers, a good Y-pipe, 3" cat, and 3" catback is a tried and true modification.
Old Mar 12, 2017 | 02:15 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Re: Cat removal
Neighbor has a Dodge pickup, V8. Took the muffler completely off, uses the cat as a muffler. Really sounds good, straight pipes clear out the back.
Old Mar 12, 2017 | 03:20 PM
Re: Cat removal
That's almost what I did to my 5,7 V8 TPI.
Unbolted the exhaust after the catalyst, knocked half of the inside out ( even used a vacuum cleaner to get the small parts out...).
Removed the mufler, replaced it by straight pipe.
Great sound, no drivability issues.
Old Mar 13, 2017 | 07:24 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Re: Cat removal
Remove every single piece of the exhaust. If you don't want to do headers and y-pipe yet do the rest up in 3in exhaust for time being. Chunk the converter.
Old Mar 13, 2017 | 08:58 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: Cat removal
Harley, do you own a red s-10? thought i might have met you before?
Old Mar 13, 2017 | 09:57 AM
Re: Cat removal
no s10
