Hooker Header Crossmember??
Old Apr 10, 2017 | 11:39 AM
Drone358's Avatar
http://www.ebay.com/itm/like/4010737...&ul_noapp=true
Has anyone used this product before? It's suppose to be ideal for Long tube headers which is what I have. This could help the routing and ground clearance. Just curious if anyone has made this work. Thanks!
Old Apr 10, 2017 | 11:43 AM
Drone358's Avatar
Re: Hooker Header Crossmember??
Old Apr 15, 2017 | 09:31 PM
toddoky's Avatar
It was designed as part of the complete Hooker 3rd-gen LS swap system and was also validated to allow performing an LT1 T56 swap behind a SB Chevy in 3rd-gens...some users have successfully used it in other ways by luck, but it should not be looked at as a universal fit component.
Old Apr 16, 2017 | 09:46 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
It's a good product but it's meant for a T56 and long tubes. Badnblk has it. Most of us that have T56 and long tubes have just made our own crossmembers because this is relatively new and the prior T56 crossmembers are not ideal.
https://www.holley.com/products/exha...ts/71222005HKR
http://documents.holley.com/199r10919.pdf
Old Apr 16, 2017 | 11:19 AM
toddoky's Avatar
Hello Tibo. The crossmember was actually designed to provide installation of a 4th-gen F-body T56, T56 Magnum, TH400, 2004R, 4L60-4L70 or 4L80/4L85 transmission behind an LS engine in a 3rd-gen. Due to the specific geometry provided by the Hooker LS engine swap brackets, and the LT1 T56 being 5/8" shorter to the mount than an LS T56, it worked out to provide support for LT1 T56 swaps behind a SB also. You don't have to cut the rails open to install the nutted backing plates either, as there are already holes in the rails that allow that...you do have to drill the holes for the rear bolts however.
Old Apr 26, 2017 | 11:38 PM
nebz90's Avatar
Here are a few pictures of my th400 with the hooker x member. I did have to slightly modify it to work with my mounts
Old Apr 27, 2017 | 05:53 AM
toddoky's Avatar
Please explain what you had to modify so others will learn as much as possible from your post.
Old Apr 28, 2017 | 12:03 AM
Alice89's Avatar
I responded to Drone358 on this thread:
https://www.thirdgen.org/forums/exha...-no-duals.html
On post #38 I explained what I had to do to get the hooker crossmember to work with a T-5 (factory 3rd gen motor mount position.)
It's really easy, and the hooker crossmember is excellent.
Old Apr 28, 2017 | 06:33 AM
toddoky's Avatar
That's good information and should be helpful to others considering the same type of install
