Tips for Removing Exhaust Manifolds for the First Time
Old Jun 14, 2017 | 03:06 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
My car has 117,000 miles and I don't think it has ever had the exhaust manifolds removed. I am going to be removing them and replacing them with headers. I have read about busted bolts, etc and am hoping to gather some lessons learned and best practices so that I might have a smooth removal.
Old Jun 14, 2017 | 07:15 PM
Biledriver's Avatar
Car: 87 firebird 86 c10 90 mustang
Engine: 383 sbc
Transmission: 97 t56
Axle/Gears: Moser 12 bolt 3.73
Re: Tips for Removing Exhaust Manifolds for the First Time
The bolts most likely to break will be to the y pipe and you won't be reusing them so you won't have to worry about them. Will be a fun little project hop you put up some pics of your y pipe. Make sure you have plug wires with 90 degree boots for the headers.
Old Jun 14, 2017 | 08:03 PM
MSgt Luttrell's Avatar
Car: 1986 IROC Z28
Engine: Carburated small block 454
Transmission: Level 3 Raptor 700R4 2600 stall
Axle/Gears: Strange S60 3:73 S Trac Posi
Been there done that, I even soaked mine with penetration oil for two days before starting the project and wound up with one broken off in the driver's side head; Hope I'm wrong, but I see a head removal and a helicoil installation in your near future.
Old Jun 14, 2017 | 09:15 PM
Engine: 350 TPI L98
Transmission: WC T5
Thanks guys. I'll use penetrant, an impact wrench, and go to church. I'll post up some pics as I get it done.
Here's the headers:
They were a "rescue" from Lurbie (Jeremy), who was kind enough to work with me on packing and shipping.
Old Jun 14, 2017 | 09:26 PM
brettr81's Avatar
Car: 91 Firebird
When I broke a bolt off in the head, I just hooked up the welder, took a nut and welded the nut to the broken bolt and removed it.
Old Jun 14, 2017 | 10:20 PM
Jbuchanan's Avatar
Car: 1987 GTA
Engine: 5.0
Transmission: Automatic
Don't use an impact on the manifold to head bolts. Soak the snot out of em and use a good 6 point socket and ratchet. Impact will most definitely snap them. Don't really think you could get an impact in there anyways. Just take your time. Whatever you do, don't use a 12 point socket/wrench.
Old Jun 15, 2017 | 10:12 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
if you've never removed stock manifold bolts, look very carefully at them before you put a socket on 'em. a few of them will have a thin steel piece that can be barely visible. after the factory installs the bolts, they bend over usually 2 tangs on the shoulder of the hex. this is to prevent the bolt from loosening up over time. you will need to take a flat screwdriver or such tool to bend the tangs out before trying to remove the bolt.
i agree about penetrating oil. sometimes i lightly try to tighten the bolt before loosening. this helps work the bolt loose. in fact it's great practice when removing any steel fastener from aluminum. almost a guarantee to never snap a bolt in aluminum again.
best of luck on the manifold removal. it wont be that bad.
these are the locking tabs you must bend out/away from the hex first;
http://www.classicchevy.com/chevy-ex...lock-1957.html
Old Jun 15, 2017 | 11:22 AM
Car: 1986 IROC Z28
I tried that too, the nut would simply break off another section of the exposed stud; it's pretty clear that GM fudged on the hardness of those bolts in the 80's.
Old Jun 15, 2017 | 11:28 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
The most difficult part will be the nuts that fasten the brackets and heat shields.
The bolt will come loose and start to twist the sheet metal parts before the nut comes loose.
I heat the nut first. it makes it break loose before the bolt turns.
Old Jun 15, 2017 | 02:19 PM
83 Crossfire TA's Avatar
I always soak them in penetrant a few days ahead of time. If I know I'm doing it I might even do it weeks ahead of time and soak them every few days and drive it to get it to soak in.
That said, i've done a bunch of them, 1/3 that didn't get any penetrant ahead of starting that came out fine. AAMOF, most have a few bolts loose enough that you can usually get them out with your hands.
As has already been said, typically the hardest part is the studs that have nuts on them holding a bracket or other sheetmetal, and about half the time I've broken one or more studs attaching the y-pipe which usually doesn't matter if you're not re-installing them (I typically soak them down, then get under the car with an impact and extension and assume I'm going to break them off but sometimes the nuts come off fine)
