Magnaflow 16450 Y-Pipe back in stock?
Old Jun 16, 2017 | 12:32 PM
Galaxie500XL's Avatar
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
All;
Looking to replace a sorry looking Y-pipe on my '88 L98.
Older threads show the 16450 Magnaflow Y-pipe no longer being made, but Magnaflow's website, and several other sites imply this is no longer true.
Is Magnaflow making the 16450 Y-pipe again?
Old Jun 16, 2017 | 01:50 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Re: Magnaflow 16450 Y-Pipe back in stock?
I have been seeing them on sale on Amazons website.
Old Jun 16, 2017 | 04:26 PM
Car: 1988 IROC-Z
I wanted to make sure they're the real deal, so that helps a bit.
The previous owner cobbed up some sorry exhaust system--according to the casting numbers, the exhaust manifolds were actually used on a mid '70's midsize car.
I've gotten the correct l98 exhaust manifolds, but the Y-pipe will have to be replaced as well with one the proper size/shape that isn't 2" in diameter, and I've heard good things on here about the Magnaflow pipe.
Old Jun 17, 2017 | 10:30 AM
(Anthony)'s Avatar
I just received mine on Tuesday from Summit. They are back in stock.
I'm going to replace my low output manifolds with HO manifolds along with the Magnaflow 16450. Going in the shop on Monday so I hope all goes well. It should be a nice, effective upgrade to the tiny piping on it now.
Old Jun 17, 2017 | 12:04 PM
Car: 1988 IROC-Z
I'd be very interested in hearing your results, since that is exactly what I'm going to be doing.
Old Jun 17, 2017 | 06:31 PM
NoEmissions84TA's Avatar
I have a set of those manifolds that I'm never going to use.
I'm in CT, so anyone else nearby looking to do the same can PM me.
Old Jun 17, 2017 | 11:50 PM
(Anthony)'s Avatar
I wish I knew before I bought my manifolds. I would rather have had OEM as I was pretty disappointed in the Dorman replacements "made in China". I should have expected it...I hope they hold up.
I suppose I should have posted a want ad.
Old Jun 24, 2017 | 07:30 AM
(Anthony)'s Avatar
Just an update for you.
My exhaust went on the car, however, not without problems. The manifold bolts broke off (4 on each side) even with heat applied and a professional mechanic doing the work.
With that said, once the manifolds were actually on, the y-pipe went up pretty nicely even without the spacer. If I remember correctly he used a larger donut gasket and did have to grind a very small bit of material off of the frame to get the final clearance.
Old Jun 24, 2017 | 06:00 PM
Good to hear.
Old Jun 24, 2017 | 07:35 PM
Car: 1988 IROC-Z
Any notable performance changes?
Old Jun 30, 2017 | 02:32 PM
(Anthony)'s Avatar
I'm not quite sure about the performance just yet as it is back at the shop for inspection. I simply have not had a chance to drive it. When I do, I will report back.
Old Jul 17, 2017 | 06:05 PM
(Anthony)'s Avatar
Well, I was finally able to take my car out for an extended cruise over the weekend and thought I would give a little update, as requested.
Overall, the car pulls very nicely at mostly all rpm's. I say mostly because I do not like to take the rev's up all the way.I can definitely feel the difference from when the car has the L.O. manifolds, y-pipe and exhaust. In my opinion you can't go wrong with a setup such as this and it flows very nicely. I'm very pleased but then again, I am a cruiser who enjoys to get on it from time to time.
Old Jul 17, 2017 | 06:07 PM
(Anthony)'s Avatar
I should also mention, I did add the MAC test pipe that I had in place of my converter if that makes any difference. I just did not want to shell out any extra money at the moment for the converter.
Old Aug 4, 2017 | 06:01 PM
Car: 1988 IROC-Z
Thanks for the info, Anthony!
I have to drive down to Georgia here in a couple of weeks, and usually stop by Summit on my way down.
