Removing AC compressor
Old Aug 6, 2017 | 02:53 AM
sjorgens's Avatar
Car: 1984 Firebird Trans am
Engine: 5.0 HO 4BBl
Transmission: one that kind of works
Axle/Gears: some that turn the wheels
Does removing my AC compressor affect any smog components? Where is the smog pump located?
I just want to remove the AC compressor but I don't want to make passing smog an issue in October. I'm in California.
Cheers!
Old Aug 6, 2017 | 11:13 AM
Ghettobird52's Avatar
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Re: Removing AC compressor
Removing ac compressor wont affect smog in any way.
Old Aug 6, 2017 | 12:41 PM
sjorgens's Avatar
Engine: 5.0 HO 4BBl
Thanks Ghettobird52!
Old Aug 7, 2017 | 12:45 PM
kfsullivan's Avatar
Car: 1988 Trans Am w/ WS6
Transmission: 5-Speed
For my 1988 Trans Am the air pump was located on the passenger side of the engine just above and to the right of the water pump. The compressor is up even higher and further to the left (toward the wheel wheel). I removed my air pump and replaced with a delete pulley.
Old Aug 7, 2017 | 12:48 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
sjorgens can't do that. He's in Calismogya!
sjorgens's Avatar
Engine: 5.0 HO 4BBl
Mine is v belts so I just cut the belt to the compressor. The compressor itself is bloody hard to move, maybe I am not doing it right.
emeryz28
Oct 31, 2016 02:58 AM
IROC406
Oct 12, 2016 07:39 AM
RunawayRadio
Sep 18, 2016 10:28 PM
dbrochard
Sep 11, 2016 04:02 PM
