Stainless Works longtube headers
Old 08-09-2017, 12:54 PM
BlackMamba94's Avatar
Car: 87 iroc z28
Engine: 5.3 under construction
As anyone ran into any problem using the Stainless works longtube headers on 5.3lsx swap or any lsx swap for that matter. I am having clearance issues and I am wondering if maybe i bought the wrong ones even though they said this will work with my car.
Attached Thumbnails Stainless Works longtube headers-20170809_125507.jpg   Stainless Works longtube headers-20170809_125501.jpg   Stainless Works longtube headers-20170809_125447_001.jpg   Stainless Works longtube headers-20170809_125429.jpg
Old 08-09-2017, 12:57 PM
Car: 87 iroc z28
Re: Stainless Works longtube headers
Old 08-09-2017, 01:00 PM
Car: 87 iroc z28
Old 08-10-2017, 08:11 PM
91ls1t56's Avatar
Car: 91 Z28
Axle/Gears: Moser 9" 3.70 35 spline wavetrack
Those don't look like the ones that I got, they look painted. I used the stainless works ls swap long tubes and they fit very well. I did have to bash in the transmission tunnel for O2 sensor clearance, but that was minor.
Old 08-11-2017, 12:12 AM
Car: 87 iroc z28
I got them ceramic coated. Did you do any other modifications to make them fit like new k member, or something. And thank you for responding back my friend.
Old 08-13-2017, 10:28 AM
91ls1t56's Avatar
Car: 91 Z28
I did use a tubular K member and I have a manual transmission. The driver side was tight, I had an inch between the header and frame rail so I relocated the fuel, brake and evap lines. I definitely have more room on the passenger side. It looks like it is up against the frame rail in your pics. Your pics look like you have clearance issues with the A arm knuckles on the K member, I did not have problems like that.
Old 08-14-2017, 08:32 AM
Car: 87 iroc z28
okay thank you for your help i truly appreciate it
Old 09-20-2017, 02:51 PM
rodneyrb's Avatar
Car: 1992 Pontiac Firebird
Engine: 04' 5.3 Liter
Transmission: LS1 T56
I also installed Hawks Stainless Headers on my 5.3l upgrade into a 3rd gen. Very tight on passenger side, but all fits and works well. My problem is, when I rev engine, Y pipe slams into driver frame rail. Hawks Ypipe, not sure what they were thinking with this....
