Removing/Installing midpipe without a lift
Old Dec 6, 2017 | 01:25 PM
poketad's Avatar
Car: 89 Iroc Z
Hey everyone, sorry to make another post but do you know how to removed the midpipe without a lift? I have the car jacked up probably a foot and a half and I can't seem to get this thing out. I'd just cut it out but then I wouldn't know how to get the new one in haha. Thanks in advanced
Old Dec 6, 2017 | 01:47 PM
kaos420's Avatar
Car: 88 gta
Engine: 5.8
Axle/Gears: 3.73 POSI
Re: Removing/Installing midpipe without a lift
If possible jack it up more..drop the rear end down should come out.or cut it an put a band clamp on it..most aftermarket ones are cut right at the axle for that reason..
Old Dec 6, 2017 | 01:48 PM
Biledriver's Avatar
Car: 87 firebird 86 c10 90 mustang
Engine: 383 sbc
Transmission: 97 t56
Axle/Gears: Moser 12 bolt 3.73
Probably have to just about completely remove the rear end. Sounds terrible but I had to do it to remove the pipe to get the gas tank out once. If you have disc brakes you can hang the calipers and brake lines to avoid re bleeding them.
Old Dec 6, 2017 | 06:37 PM
Drew's Avatar
Pull the wheels and get the axle as low as possible.
Old Dec 6, 2017 | 07:51 PM
poketad's Avatar
Car: 89 Iroc Z
Thanks for the responses everyone, and yeah, looks like its going to be a fun time haha.
Old Dec 6, 2017 | 09:29 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Disconnect the shock at the bottom. The rear axle will drop much lower. Watch the brake lines.
Old Dec 7, 2017 | 10:52 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
don't pull the rear. remove the tire, shock, spring and control arm on right side and slide it in.
Old Dec 11, 2017 | 12:40 PM
82tarecaro's Avatar
Disconnect the track bar and the shocks and the rear will drop down enough to get the exhaust out or in. I never tried it the way naf said, but it makes sense that if the spring and control arm were out of the way, it would probably slip in through the side.
Old Dec 12, 2017 | 12:47 PM
gt4373's Avatar
Transmission: 5-Speed Manual
https://www.thirdgen.org/forums/exha...ll-walker.html
