Anyone see this Speed Engineering setup?
Old Mar 13, 2025 | 09:08 PM
  #101
Pocket's Avatar
Car: 91 Trans Am
Re: Anyone see this Speed Engineering setup?
Since posting above I have this exhaust and I did some extra fitment fabrication to hug the bottom of the car. I had many of the sections cut and re tig welded to hug my undercarriage. This was not cheap. I cannot emphasize this enough, as I turned a $300 kit into 4 digit custom exhaust. I have enough exhaust for anything but I am already considering going to a single 4". The drone in unbearable. I will experiment with some different mufflers but fitment is a major issue and I really only have room for bullet style.
Pros:
Leaves no power on the the table
Looks super pretty
Con's
Major expense if you want it to hug without scraping
DRONE
DRONE
First, that system looks absolutely killer with all the custom fitment
Second, have you looked into helmholtz pipes/J-tubes? I know, adding more exhaust isn't high on your list, but it's really not bad. There's ample space under the heat shield where the OG muffler went. Most V8's want tubes 20-30". Dual systems need their own respective tubes. The J-tube pipe diameter doesn't need to match the system either, so smaller 2.25-2.5" will work if it helps packaging
https://www.pro-touring.com/threads/...-Exhaust-Drone
Old Mar 13, 2025 | 09:23 PM
  #102
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I have looked at them but they were more system level options. I guess I never thought about making a custom one. That link is super helpful. I need to spend some more time on this. If it weren't for the drone I'd be super happy. At WOT it's a symphony of murica.
Old Dec 31, 2025 | 09:25 AM
  #103
badtenant's Avatar
Car: 92 RS
Transmission: TKX
@ShiftyCapone Exhaust looks great! What cats did you end up using?
Old Dec 31, 2025 | 09:53 AM
  #104
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I bought them off amazon, fablab motorsports is the brand. They seem to be good so far.
Edit: That is not the brand. Ill have tl dig through my notes but I know they are an off brand high flow universal.
Black Knight
Dec 26, 2012 01:51 PM
chevymec
19
Mar 1, 2012 06:28 AM
Untamed Z
Fabrication
May 15, 2008 04:42 AM
Malkster
Car Audio
Feb 28, 2003 09:22 PM
