G8 Accessories
Old Dec 24, 2012 | 02:18 PM
Black Knight's Avatar
G8 Accessories
Hello All
I tried doing a search but was not able to find out how an accessory setup from a G8 would work in an third gen.
Can anyone shed some light?
Old Dec 24, 2012 | 05:01 PM
Flip 2's Avatar
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
Re: G8 Accessories
Not sure anyone has tried a G8 setup. Be interesting to hear who chimes in.
One thing to look for is distance in front of the engine. I used a C5 accessory setup and the a/c compressor was an issue, because the Corvette setup is 3/4" closer to the motor than the commonly used F-car setup.
Old Dec 26, 2012 | 01:51 PM
Pocket's Avatar
Car: 91 Trans Am
Re: G8 Accessories
Rough layout is similar to the Fbody accessories
Depth is an issue when mixing/matching as most VVT/DOD engines use truck spacing. If you're using all G8 stuff, then it will definitely fit. Mixed kit would require measuring
BDR
Nov 7, 2015 03:05 PM
355tpipickup
Sep 28, 2015 05:50 PM
evilstuie
Sep 24, 2015 02:31 AM
Camaroguy2
Sep 22, 2015 08:22 AM
Mdenz3
Sep 17, 2015 08:36 AM
