LS1, T56, spoon crossmember, Hawk's longtubes what to fo about Y-Pipe?
Old Dec 25, 2012 | 06:50 PM
keith42's Avatar
Car: 1987 Iroc
Does anyone make a Y-pipe to work with this crossmember or should I have a custom one made?Name:  transcrossmember004.jpg
Old Dec 26, 2012 | 06:45 AM
Flip 2's Avatar
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
Re: LS1, T56, spoon crossmember, Hawk's longtubes what to fo about Y-Pipe?
I think most folks are using the Hawk's double humped transmission mount (the Skulte original has been discontinued- Skulte has closed and moved on).
Old Dec 26, 2012 | 09:17 AM
25th327RS's Avatar
Car: 92 Ttop Z28
Engine: Cammed 6.0
Axle/Gears: Built 10 bolt-3.90s w/ PBR discs
I wish spohn would make a double humped crossmember with the torque arm mount on the crossmember. Looks like the only option without hand fabricating, is hawks double hump crossmember, and BMR's trac-pack torque arm.
I have had my spohn crossmember mounted TA on my car for less than 100 miles and now I have to ditch the whole setup!
Old Dec 26, 2012 | 09:42 AM
keith42's Avatar
Car: 1987 Iroc
why do you have to swap it out?
Old Dec 26, 2012 | 11:35 AM
25th327RS's Avatar
Car: 92 Ttop Z28
Engine: Cammed 6.0
The crossmember mounted torque arm crossmember is built the same way as yours, which poses an exhaust routing issue with long tubes( which previous to my ls swap, I did not have). To make exhaust without sacrificing ground clearance, ou usually swap to a double hump crossmember for exhaust clearance. They just don't make one that has a torque arm mount on the crossmember.
Old Dec 26, 2012 | 11:54 AM
25th327RS's Avatar
Car: 92 Ttop Z28
Engine: Cammed 6.0
Hawks makes longtube y-pipes, but I believe is only for the smaller sized headers. Even with those, most are not happy with fit and quality. You are pretty much on your own for a ypipe, but the double hump crossmember makes it MUCH easier, and gives you more ground clearance when doing so.
Old Dec 26, 2012 | 12:58 PM
Flip 2's Avatar
Engine: C5 LS1
I did 2 1/2" y into 3". Got good ground clearance... friend who did exhaust worked at it.
Using a Spohn trans mounted Torque Arm.
Old Dec 26, 2012 | 01:56 PM
Pocket's Avatar
Car: 91 Trans Am
Hawks makes a 2.5" Y-pipe to go with crossmembers like that. You'll have to modify it to fit your flanged headers as it is designed for slip fit collectors
http://www.hawksthirdgenparts.com/pr...logy-Cats.html
I have one FS if you're interested
Old Dec 26, 2012 | 02:12 PM
keith42's Avatar
Car: 1987 Iroc
thanks for all the replies, looks like I'll be fabbing my own Y-pipe
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
kammi10
Nov 9, 2015 08:28 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
