Smog pump delete help.
Old Jul 26, 2018 | 01:27 PM
Jon_89RS's Avatar
So I have an 89 with a 305 TBI and want to delete the smog pump. Was wondering what size bolt I could use to plug the holes in the exhaust manifold. I was reading that you can weld them shut but I do not have a welder. Thanks in advance
Old Jul 26, 2018 | 01:48 PM
Drew's Avatar
Re: Smog pump delete help.
Search for "AIR inverted flare thirdgen.org" with google, betcha find your answer in detail.
Old Jul 26, 2018 | 06:29 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Old Jul 27, 2018 | 12:13 PM
83 Gman's Avatar
1/4" brass NPT plug. Go to whoever and buy 8. Take the tubes off and just screw the plugs in till them stop.
Old Aug 1, 2018 | 02:07 PM
RunawayRadio's Avatar
Car: 1987 GTA, Digital Dash
Engine: L98 TPI
Transmission: 1994 LT1 T56
Axle/Gears: 9 bolt, 3.27
While that will work, it'll fit poorly and can leak without sealing the threads. The correct fitting is a 5/16" inverted flare plug.
They're hard to find these days but they can still be found on ebay or fastenal for a decent price.
Edit: Here you go: https://www.ebay.ca/itm/Inverted-Flare-Fittings-Steel-Fitting-Plug-5-16-Tube-/232322680575?var&hash=item0&_uhb=1
Old Aug 1, 2018 | 03:23 PM
83 Gman's Avatar
I forgot all about using them. Thanks for the memory jog.
Old Aug 4, 2018 | 07:33 PM
GeneralDisorder's Avatar
Eh I just used brass plugs NPT plugs and they worked fine for the year or so before I pulled all that junk off and installed Dyno Don headers.
At $28 for 10 of those inverted flare fittings I think I would live with some leakage. Which honestly if you gorilla those soft brass NPT plugs in there they will conform and they aint going to leak.
Sure it's not "right" but then neither is deleting the AIR system and the RIGHT way to do this is with some proper headers.
GD
Old Aug 5, 2018 | 07:05 AM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
Now I did not do this...a PO of my car did, My pipes are cut right at the nut and the hole is filled with Epoxy. I am to assume they could not break the nuts loose. I would rather have the plugs that can be bought but I have had the car for over 3 yrs and it has not blown out nor does it look horrible as it is a clean cut with no pipe sticking out. This is not the proper route to go but if you can't get those nuts loose I guess this does work.
Old Sep 23, 2018 | 07:03 PM
Gunreaper's Avatar
What are you guys doing with the pipe coming up on pass side by firewall which comes from the cat under the car?
plug it down by cat?
Old Sep 23, 2018 | 08:56 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
This is what I did. It's a stainless steel compression fitting and cap for 1/2" tubing.
I put the original clamp back on after the pic was taken.
Attached Thumbnails Smog pump delete help.-20180806_210524.jpg   Smog pump delete help.-20180806_210210.jpg
Old Sep 23, 2018 | 08:59 PM
T.L.'s Avatar
By the way, regardless of what you use to plug the manifolds, those fittings ARE NOT NPT. They are 1/2"-20 straight thread (bolt thread)...
Old Sep 23, 2018 | 09:38 PM
Gunreaper's Avatar
I may do that then. I just want to drive the car a little while I am waiting to order headers
Old Sep 24, 2018 | 09:33 AM
Does not matter. Brass is soft enough that it seals up just fine. And who is going to put the tubes back on? No one. So if the threads get buggered it doesn't matter. This just a short term solution before they get ripped out and headers get installed.
Old Sep 24, 2018 | 09:43 AM
T.L.'s Avatar
That was just a F.Y.I.
I don't plan to put headers on this car, and while I hope I never have to re-install the AIR tubes, it can be done...
Old Sep 24, 2018 | 08:41 PM
Gunreaper's Avatar
I was removing my smog pump and ran into a problem! Got the pulley off, got the top torx 40 bolt out but the bottom bolt torx stripped.
at work I have a torx 40 plus which is bigger and the snap on guy will be there. Any ideas?
Old Nov 23, 2018 | 05:54 AM
buffaloman's Avatar
Car: 1989 Firebird Fornula 350
Engine: 350 L98 / NOS
Transmission: 4sp Auto
Did this on may 1983 T/A and the thread size was M13 x 1.5. As I had a NOS air pipe to measure the threads. I used these:
https://www.ebay.com/itm/M17-Kit-Rep...72.m2749.l2649
noboostnogo
Sep 8, 2009 05:15 PM
Camaro Z Man
Aug 19, 2009 11:59 AM
xcel92
May 1, 2009 09:03 AM
I-Roc with my Z
Jan 21, 2005 03:34 PM
