Headers w/o AIR pipes and 3" Y-pipe outlet
Old Jul 29, 2018 | 06:59 PM
nortron's Avatar
Car: 1987 Firebird Formula 350
Engine: 5.7 Vin 8 L98
Transmission: R-700 Auto
Axle/Gears: factory
This question has probably been posted somewhere before but I still can't find a solid answer.
Does any header company make a set of shorty headers and Y-pipe that fits the 350 with a 3" single cat inlet AND, (here is the tricky part) does NOT have the AIR tubes and requires no welding of the Y-pipe to fit ? I can't find headers that meet those requirements anywhere except Dyno Don's and I have been unable to contact him through this web site. I don't even know if he is still in business. I don't have a welder and just want a set that I can just bolt on and go. Thanks for any input.
Old Jul 29, 2018 | 07:07 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: Headers w/o AIR pipes and 3" Y-pipe outlet
Lon carries DynoDon's products through his TDS site. You can also reach Lon via PM on this site (lonsal), or he may reply here as well.
http://www.top-downsolutions.com/
Old Jul 29, 2018 | 07:50 PM
nortron's Avatar
Axle/Gears: factory
Thanks DynoDave. Yes - I did see in my searching that TDS sells the Dyno Don's headers wihout AIR tubes, but his matching Y-pipe requires fitting, welding and sending out for ceramic coating (+$200). I'm doing this in my garage at home and don't have access to a mig/tig welder or the experience to do it. I guess I could try and find a local welding shop to do the welding but I would much prefer a setup that I can just bolt on. I find it hard to believe that with all the Third Gen Camaros and Firebirds out there that somebody does not make a bolt on system without the smog AIR pipe headers.
Old Jul 29, 2018 | 09:54 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
I do, but for shipping purposes the 3" outlet has to be welded after install.
Send me a PM
Old Jul 29, 2018 | 11:04 PM
nortron's Avatar
Axle/Gears: factory
Thank you for the update. I appreciate you getting back. I'll have to try and find a local shop to do the final welding.
Have a great day.
Old Jul 30, 2018 | 07:48 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Hooker 2460 1 5/8 primary and 3" outlet. They also come in ceramic
https://www.summitracing.com/parts/hok-2460hkr
Old Jul 30, 2018 | 08:37 AM
nortron's Avatar
Axle/Gears: factory
Thanks for your reply.
I looked at those headers as well. The headers have a 3" dia. collector where they go into the Y-pipe, but unfortunately the matching Y-pipe is only a 2.5" dia. outlet (to the cat). I need a 3" dia. Y-pipe outlet. Maybe Hooker has one but I'm not seeing it anywhere for these headers. I know they have a 3" dia. Y-pipe that works with the 2055 headers but I don't know if that one would work with these 2460 headers. I can't get an answer from Hooker. I don't even know if they sell that 3" dia. Y-pipe separately or not.
If you have a 3" cat back on your car (like I do), how did you manage with the 2.5" dia. outlet Y-pipe?
Old Jul 30, 2018 | 08:40 AM
midias's Avatar
Most people here cut off the 2.5" section and weld on a 3"
Old Jul 30, 2018 | 08:49 AM
nortron's Avatar
Axle/Gears: factory
That seems to be the only solution so far. I don't have a welder so I would have to find a local shop somewhere.
Thanks.
Old Jul 31, 2018 | 05:09 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Go with Dyno Dons. They are way better than all the rest. He the only one that makes them with 1 3/4in tubes and the exhaust flow and construction is better than the rest. You are guaranteed to run in the mid 13’s@102-104mph in a stock L98.
Old Jul 31, 2018 | 08:58 PM
nortron's Avatar
Axle/Gears: factory
Thanks Vincent. appreciate the input.
kukerdan
May 23, 2011 11:43 PM
Carlos773
Jan 25, 2011 07:14 AM
rescuesigns21
May 20, 2007 03:03 PM
