Summit sells Catco at $92, Can I do better?
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
What is a good price for Catco Hi-Flo Cat? I see somewhere that they go for 50 dollars but summit sells them for 92, can i do better?
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Which cat are you talking about?
I bought a 3" univ cat from Summit for $60 shipping included.
how hard was that to do? i have a mig welding and arc welder here at the school and a teacher for help, except i need info, how do i cut/mig the front of the cat? is it hard?
the back is bolts so no question there... anyother info?
i need one too so im up for a GP!
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I bought the $48 Catco 3" from Summit, too.
The universal 3" doesn't have a flange on either end.It's made to weld-in or slip-fit. I had the muffler shop weld a three bolt flange on the "out" side of the cat to make it easier to get the exhaust off.
-Rich-
-Rich-
Too be honest id suggest u have someone else do it. I really dont know how knowledgeable u are behind a welding machine. U can make a hole if its too hot or just ruin it. Let the experts handle this one.
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
so are you saying that i should either stick with the direct bot in model or if i get the unversal that i let a pro do the job?
yeah thats ur best approach, if i were u id get the direct bolt on, if u buy a universal 3 inch catco ur gonna need a 14" in length pipe cause the cat is short, so get the bolt on. unless u have the money its all up to u.
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
it does sound cheaper to stick with the bolt on, so ill do that, ill be buying my new custom 2.5 hooker exhuast setup in a week or two, so ill let you guys know how it turns out.
Stangski09
Nov 14, 2015 01:27 PM
raymondandretti
Exterior Parts for Sale
Sep 6, 2015 12:51 AM
