Hooker 16767 Y pipe is NOT 3” Anywhere
Old Feb 11, 2020 | 07:40 PM
82Firebird5.0's Avatar
Car: 1982 Firebird
Engine: 5.0 LG4
Transmission: 200C
Axle/Gears: 2.73 open diff
Kinda disappointed, just was fooling around with car parts and happened to measure my new hooker y pipe. In NO place is it 3” it’s 2.5 all around. The hooker website literally says inlet 3” outlet 2.5”. What the heck!!! The actual flange makes it about 3” on the inlet but the actual hole is only 2.5”!??! it just doesn’t make sense why they’d flow 3” 2460 headers into a 2.5” y pipe and waste that half inch. And the reason I bought the hooker was because I thought it was 3”. Could’ve saved 100$ and got the Doug’s ones (they say 2.5 inlet, 2.5 outlet. Can anyone explain this I’m not super happy
Old Feb 11, 2020 | 08:41 PM
toddoky's Avatar
Re: Hooker 16767 Y pipe is NOT 3” Anywhere
Can you post a link to the web listing that states the Y-pipe is 3” in diameter? I just checked the listing for that part on Holley’s website and it describes it as being 2.5” O.D.
Old Feb 11, 2020 | 08:58 PM
Drew's Avatar
It's pretty well known that Y pipe transitions to 2.5" at the Y outlet. That's why there threads about cutting it at the Y and welding in 3" pipe. The Doug's isn't any different, it's an interchangeable copy of the Hooker Y. You'd still have to cut/weld it.
Part of the problem is the stock exhaust is about 3" into the single cat on "HO" cars, and the exhaust from the cat back is 2.75" that then necks down to 2.5" when it enters the muffler. What you end up with is people talking about their 3" exhaust that have never measured anything, or paid attention to how the stock setup changes size, etc. I.e. there's a lot of confusion out there.
Either cut it off and have someone weld 3" pipe onto it, or send it back and fab the entire Y-pipe from scratch. Next time read the descriptions more carefully so you know what you're buying..
Old Feb 11, 2020 | 10:02 PM
Car: 1982 Firebird
Engine: 5.0 LG4
Transmission: 200C
i measure a few spots though, there is nowhere where it’s 3” so how could I cut it? Or you mean keep the “arms” of the Y as 2.5 and join them as 3”
Old Feb 11, 2020 | 10:03 PM
Car: 1982 Firebird
Engine: 5.0 LG4
Transmission: 200C
https://www.jegs.com/i/Hooker-Header...16767/10002/-1
it says inlet diameter 3” I thought that meant the “arms” of the y would be 3” maybe just a misunderstanding on my part
Old Feb 12, 2020 | 03:43 AM
toddoky's Avatar
Just so you are aware, that is a reseller’s website description, of which Holley/Hooker has no involvement in creating or controlling.
Old Feb 12, 2020 | 06:49 AM
Car: 1982 Firebird
Engine: 5.0 LG4
Transmission: 200C
oh gotcha, my bad then. Sorry if I came across wrong. For my build I’m sure 2.5 will work fine. 3” headers to 2.5 and then to the stock catback for now. Then eventually I’ll upgrade to a better catback and maybe have a 3” welded into the hooker. Other engine mods are a bigger cam (torque cam) and a different air cleaner. I also have been completely refreshing the heads, new exhaust valves, valve seals, new guides, reground intake valves w backcut for more flow, reground seats and new springs.
Old Feb 12, 2020 | 08:50 AM
toddoky's Avatar
I'm glad you posted about your concerns as it gave me an opportunity to check the product listing on the Holley website and make sure the information was at least correct there. Good luck to you on your project.
Old Feb 12, 2020 | 09:32 AM
Drew's Avatar
Thinking they meant 3" inlets from the header collectors.
Used to be the Y was two curved pipes welded to a 3rd pipe. Cutting the third off and replacing with 3" was possible. But looking last night, some of the photos show a stamped Y piece that might make that impractical.
Hooker would be a lot further ahead if they changed it to Y into a 3" pipe, since that's pretty much the defacto standard for thirdgen stock style exhausts for over 20 years.
Old Feb 13, 2020 | 03:30 PM
Car: 1982 Firebird
Engine: 5.0 LG4
Transmission: 200C
especially for $300!
mdtoren
Mar 19, 2014 10:24 AM
Looksthakill
Jan 14, 2011 02:04 PM
flexxedout88
May 5, 2010 07:22 PM
Bobbyz
Feb 25, 2003 02:23 PM
