Looking to purchase full exhaust, recommendations wanted
Car: 1985 Trans Am
Engine: Chevy 355
Transmission: T5 NWC
As in the subject, I'm looking to replace the full exhaust on my 85 TA. I had bought some headers on Ebay a few years ago just to get the exhaust functioning, and now it's time to redo the whole thing the right way. I ready the stickies and there's a ton of info, but it's mostly about which catback is better, which cats to use, etc. What I'm looking for, ideally, is a bolt up FULL axle back exhaust, and recommendations about what to buy. I'm not looking to spend a fortune, so under a grand would be best, if possible. Once I've got some ideas and advice, I'll search the sound clips and pick one out, I'm just looking for a place to start. Also, I have a deep sump oil pan on my 350, I don't think that will interfere with routing but it's worth noting. Thanks in advance guys.
Car: 1986 Pontiac Firebird
Engine: 383 SBC
Axle/Gears: Hawks 8.8 with 4.10’s
Re: Looking to purchase full exhaust, recommendations wanted
If you’re running the eBay long tube headers and you’ve already installed them and the oil pan then a catback exhaust will be of no consequence to that oil pan’s fitment. In fact the only thing to be concerned over fitment with the LT’s would be any kick outs the pan has but even then it seems unlikely. With your $1k budget for exhaust after the headers you can have the best as I don’t know any exhaust system that exceeds that price point. Close but not exceeding. I don’t recommend the Hooker aerochamber catback personally unless you have the mechanical ability to work it. I have it, it’s cheap but the fitment was iffy, modified I made it work.
Car: 1985 Trans Am
Engine: Chevy 355
Thank you for the advice, I will steer clear of the aerochamber.
I have ebay shorties unfortunately, and they say they don't use the same y pipes as other shorties do, but i matched them up exactly to the unknown ones that came out of the car, which were pretty beat up. So my dilemma is, if I can't confirm what Y pipe I can use for these headers, I think I have to replace them instead of guess on fitment, you know?
Car: 1985 Trans Am
Engine: Chevy 355
And I do have a really nice true dual setup on the car currently that the PO installed, would need full sanding and paint, but it's do-able. I'd have to figure out the ground clearance issue, but it could be done I imagine. I doubt any Y pipe setup would flow like a 2.5" true dual, so maybe I'm wasting my time replacing the full exhaust. As you can see, I'm pretty torn on this one haha
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
I had the Aerochamber on my car and loved it. I switched to Magnaflow back in 2007 to sound different from other 3ed gen Fbodies. Now alot of third gen guys have Magnaflow and dont use Hooker. Ironic
Car: 92 Camaro
Axle/Gears: S60 373
If you have the coin for it, go for the Hooker Blackheart exhaust. A decent exhaust shop can make you a dual cat "y pipe" and use the x pipe back from the above mentioned system. It's quite popular with LS swapped third gens
Engine: 383 SBC
Engine: 383 SBC
Car: 1985 Trans Am
Engine: Chevy 355
I've done 100% of the work on this project myself, with the exception of the windshield, so I'm looking to avoid work that should be done by a shop wherever possible.
Thanks for the info about the oil pans, I have a couple of stock ones kicking around that I can clean up and paint to save me some space. I don't really see the need for the deep sump pan, it's just what came with the motor.
Does anyone know where I could get a set of Dyno Don's headers and Y pipe? I did some browsing yesterday and saw that he stopped doing it, so do I just need to wait for them to pop up somewhere?
Car: 1988 IROC-Z/G92
Engine: 5.0
Axle/Gears: BW 3.45 Eaton Truetrac
Send him a message on the forum, Im ordering a set next Friday. Let me know what you come up with as far as the rest of the exhaust...
seanof30306
South Central Region
Aug 30, 2016 12:17 AM
