Air Tube Delete
Engine: 87 5.0L TPI
Air Tube Delete
83 Z28 with 87 305 TPI, upgraded to 90-92 Speed Density system. I have removed the AIR system and plugged the ports in the manifolds with stainless steel plugs. I was wondering do I need to plug off the air tube input on the side of the cat? If so, how are others doing it
Engine: 5.7 L98
Re: Air Tube Delete
I would pinch it off, you could pinch it and then weld over for good measure to be sure its sealed against exhaust leaks.
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Air Tube Delete
I left a short secttion and capped it of with a stainless steel compression fitting...
