I really need your help about this..
Old Jan 20, 2002 | 05:33 PM
DiecastZ28's Avatar
I just ripped out my exhaust. It was all cobbed to hell. Reducers every where A clamps holding everything up. It was a flowmaster exhaust. The kid before me cut the cat off and put a straight pipe and it hurts me to see how cobbed it is. The damn thing must have leaked everywhere. I am wondering what is the stock size exhaust pipe from the cat to the muffler. I am wondering this because he had a reducer goin to the inlet and on both outlets. Should it be just a direct fit?
Old Jan 21, 2002 | 01:26 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
By "reducer", I assume you mean the muffler flange was bigger than the pipe. If so, that's good.
You're in the perfect position to make that exhaust better than it ever was before. If there's still anything factory attached to the heads even, get rid of it, too. The LG4 exhaust stinks to high heaven, and anybody who told you the stock size so you could duplicate it would be doing you a disservice.
Get headers made for '86-up TPI with y-pipe. It will have a connection to a 3" slip-fit cat. Then get a direct-fit cat and I-pipe for the same application. It will have a bolt-type flange on the cat outlet, and 3" back to the muffler. At that point, if your muffler inlet is less than 3" but more than 2-1/2", a reducer isn't going to hurt you that much. The tailpipes should be 2-1/4" or 2-1/2".
If you can't afford headers & y-pipe, at least get LB9/L69/L98 exhaust manifolds and go from there (I just happen to have an LB9 set available...).
Old Jan 22, 2002 | 03:20 AM
Jza's Avatar
Jza
^^^ this is all a good idea, and shouldn't cost a whole lot. ^^^
STIFFLER
Jan 1, 2003 06:18 PM
Skatepunk60
Dec 25, 2002 01:28 AM
definitive1
Aftermarket Product Review
Dec 20, 2002 10:34 PM
Hrock
Dec 17, 2002 11:49 PM
92fire-audio
Sep 5, 2001 12:10 AM
