1983 L-69 Stock exhaust
Old Aug 12, 2023 | 08:52 PM
tonydijr's Avatar
Car: 1983 Z-28 L69 H.O.
Engine: 5.0 HO
Transmission: 5 speed
Want keep this L-69 stock. Looking for OEM 3" pipe from cat back.. Has anyone replaced or substituted this with aftermarket 3" pipe.
Old Aug 12, 2023 | 10:59 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Re: 1983 L-69 Stock exhaust
I haven't used this, but I wish I knew about it a couple months ago.
https://www.top-downsolutions.com/po...product_id=232
Old Aug 13, 2023 | 09:45 AM
Why? The stock L69 exhaust necks down to 2¼" or so at the muffler anyway.
The Hooker system bolts right up to your cat if you make the right adapter (4-bolt plate with a oval to 3" section), does away with the restrictions in the stock system, follows the stock routing and mounts to the stock hangers, and looks very much like stock, if you use simple turndowns instead of the Hooker tips at the exit.
Old Aug 13, 2023 | 11:36 AM
tonydijr's Avatar
Engine: 5.0 HO
Thank you for response, very interesting site
Old Aug 13, 2023 | 11:43 AM
tonydijr's Avatar
Engine: 5.0 HO
Well Thank you for that suggestion. Your knowledge is appreciated. I was not aware of the Hooker setup. Would you happen to have any numbers on the Hooker item or can I find it on just a search of their site..
Old Aug 13, 2023 | 11:48 AM
chazman's Avatar
Axle/Gears: BW 3.45
Whatever you get will require the exhaust shop to transfer the 4 bolt flange from your cat, if you still have it.
Old Aug 13, 2023 | 12:27 PM
Sure, I'll look it up for you.
https://www.summitracing.com/parts/hok-16823hkr
You can see pretty clearly what I mean about the tips.
Old Aug 13, 2023 | 02:17 PM
tonydijr's Avatar
Engine: 5.0 HO
Thank you. I didn't search thru Summit, guess that is why I couldn't find it. appreciate your help..
chazman
May 28, 2008 10:41 PM
84bandit
Mar 16, 2007 05:16 PM
phess11
Apr 18, 2005 07:32 AM
Wishmaster's87IROC
Jan 1, 2003 12:12 PM
