Does removing the cat make the car louder??
Old Feb 8, 2002 | 11:05 PM
CamaroX84's Avatar
I currently have Hooker Headers, a high-flow 3" cat, and the 3" Flowmaster cat-back on my car (355 TPI). It sounds nice, but it's not loud enough. I was wondering how removing the cat would affect the sound. Thanks.
Old Feb 8, 2002 | 11:08 PM
Momar's Avatar
Yes, some. It also changes the tone.
Old Feb 9, 2002 | 12:22 AM
CamaroX84's Avatar
Does it make it sound more "throaty"? Thanks.
Old Feb 9, 2002 | 12:26 AM
Momar's Avatar
It did on mine.
Ben
Old Feb 9, 2002 | 08:26 AM
87transam5.7tpi's Avatar
when I took off my cat. it made the car sound mean. before it sounded like a v6 :-)
Old Feb 10, 2002 | 10:42 AM
CamaroX84's Avatar
I have heard from people that removing the cat and having the Flowmaster American Thunder 3" cat back makes it sound like crap. But I don't know. Like I said, I have headers, and after a few more mods I'll be around 350 horsepower if that makes a difference in noise. I want it to sound like the old Camaros/Chevelles, etc. I love the popping/throatiness. Does it really change the volume and sound a lot? Thanks again.
Old Feb 10, 2002 | 10:48 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
If you want the popping sound then remove the cat because that is exactly what you will get.
Old Feb 10, 2002 | 02:09 PM
grumpygreaseape's Avatar
Car: 85 iroc,96 z28,96 Ram 2500,69RR
Engine: 383 with AFR heads.
Transmission: richmond 5 speed
Axle/Gears: 1991 w/1LE.auburn pro series.2.73's
i have 2 different cats-both the 4 bolt flange style used in 85 and i think in 84 in the ho cars. one is the original one and it has maybe 5000 miles on it, the other one is holl-wed out, which is used most frequently (daily) i am running headers too with a banks power pack exhaust. with the daily driver cat in place the car sounds so much more "crispier"-no, not like breakfast food. snappy and more huevos as an extra bonus -see food reference above- with the bi-annual necessity in place (original cat) the tone gets really muddled and power levels definitely go down. what is" popping sound", backfire? if so it aint the cat. exhaust leaks, bad a.i.r. check valves, too rich air fuel, i believe. gutting the cat alone wont cause backfiring. :lala:
Old Feb 10, 2002 | 03:09 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
I believe the popping sound he is looking for is also known as rasp. When you step on the gas, the car kind of rumbles with a "popping sound". I personally think is sound like crap, but some people like it, and removing the cat will give you that noice.
Old Feb 10, 2002 | 04:03 PM
hmmmmm...
Old Feb 10, 2002 | 10:56 PM
CamaroX84's Avatar
The popping I want is not backfiring. It is on practically all 60s-70s muscle cars. Maybe it is a "rasp." It is like being able to hear every cylinder fire with a very crisp throaty noise. I know everyone here has heard it. Thanks again.
Old Feb 10, 2002 | 11:34 PM
yes man thats what im talkin about-crisp and snappy -jfreeman, you really dont like that music? camarox84 yank it out and you will enjoy what you hear then, by all means-seeya frank
Old Feb 12, 2002 | 02:58 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
GGA - I just don't care much for the pop pop pop pop. It is kind of annoying, kind of like backfiring, just annoying. I like a constant deep rumble sound. I know there a some people that like that pop pop pop, but it just doesn't sound right to me.
Old Feb 12, 2002 | 03:23 PM
Momar's Avatar
A lot of that pop pop pop is caused by the air pump. Mined did it when it was hooked up but when I took the belt off because it squealed it didnt pop anymore. Also, I think that if that isnt what you are talking about there is some poping that you get due to somthing with the lack of scavenging or something, I just think I remember reading about that somewhere.
Old Feb 12, 2002 | 09:43 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I have headers 3in cat and 3in edelbrock catback. i put a straight pipe in for the cat and it sounded horrible. I put the cat back on.
Old Feb 12, 2002 | 09:55 PM
1970 LT1 Z-28
snappy
crispy
sharp
no washed out burble
solid lifters
no converter
dem wuz the days :rockon:
Old Feb 13, 2002 | 01:23 AM
irocEOK's Avatar
mkos1980, your straight sounds like crap you say? i have a 350, and i cut
open the cat and put a straight inside to get me through inspections, and it
sounds simply mar-ve-lous! maybe you have a 305 or something different....
what do you have on your exhaust??
Attached Thumbnails Does removing the cat make the car louder??-iroczeok.jpg
Old Feb 13, 2002 | 01:25 AM
irocEOK's Avatar
maybe its that edelbrock exhaust
Old Feb 13, 2002 | 09:59 AM
Camrs89's Avatar
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
My 72 has goes pop, pop, pop,pop when i let off the gas. I believe it is because of too much carb. I have my friends 800+cfm rochester carb on the car because it was there and it did help a good deal in power, but it still is boggy around 40+mph when you nail it
Old Feb 13, 2002 | 01:37 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
The car sounds great with the converter. its just after my head and cam swap is when the car got too loud to go with a straight pipe.
onefreakz
May 14, 2018 12:15 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
TheExaminer
Aug 26, 2015 04:59 PM
Exxon Limited
Aug 9, 2015 08:13 PM
3rdgenparts
Aug 8, 2015 07:09 PM
