Size of Tips
Old Feb 14, 2002 | 09:32 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
Size of Tips
I plan on putting on a 3 in pipe to a 80s series Flow. What size tips should I make coming out of the Flow? I am going to have two with chrome tips. Should they be 2.5 each or 3?
Old Feb 14, 2002 | 09:47 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Whatever u like.
Old Feb 15, 2002 | 09:57 PM
trans87's Avatar
Well I want to know performance wise. If there are two 3 in exit pipes will this cause some performance loss?
Old Feb 15, 2002 | 10:05 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Running 2 .5" tips on a 3" tailpipe will cause power loss. It's a restriction.
Putting 3" tips on 2.5" pipes will not cause any restriction. It won't give you any extra power, but if they are long enough (like Meg's) then they will change the sound somewhat. Adding a 3" tip/pipe to a 2.5" pipe will make it sound a little lower pitched.
Even adding/removing any amount of length on an exhaust will change it's flow characteristics, and sound.
AJ
Old Feb 15, 2002 | 11:54 PM
trans87's Avatar
How about 3 in tips on a 3 in pipe? I heard from somebody that there will be too little back pressure These tips will be coming out of a 80s Flowmaster in the back.
Old Feb 16, 2002 | 08:29 AM
Lounge Lizard 6's Avatar
I wouldn't worry about lack of back pressure from a couple of tips.
Old Feb 16, 2002 | 06:28 PM
GiddyUP305's Avatar
Engine: turbocharged 4 cyl Dohc
Transmission: 5 spd sentronic
go get some 4th gen tips
you could finish off your exhaust n a suttle way
with a pair of Z-28 tips i have these on my bird
Old Feb 16, 2002 | 06:30 PM
GiddyUP305's Avatar
check it out
this consists of a 2.5 pipe going into the Votrex muffler and 3" pipe exiting to the z28 tips they couldn't turn down the 3" pipe
PurelyPMD
May 5, 2016 04:57 PM
Nervous2
Oct 8, 2015 10:53 PM
Linson
Sep 21, 2015 01:08 PM
m00n420
Sep 11, 2015 02:39 PM
