SLP headers, and Corvette angle plug AL heads?
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
I'm posting this for a friend. He has a 91 Z-28 just got his short block together, and scored some 88 Vette heads. The question is will the angle plugs clear the 1 5/8 in primary tubes. He couldn't get a straight answer from SLP, I just wondered if anybody has this combo, without having to run weedeater plugs.
Thanks!
Thanks!
Car: CTS-V & 89 Z28 vortech charged
Engine: LS6 & 383 charged stroker
Transmission: 6-speed & 5 speed
I just looked at my SLP's on my L98 steel heads. If those plugs were turned in on angle, towards the center of the gap between exhaust ports, I would think they would work. I dont have the Aluminum heads but I have been eying them to put on my car to remove weight from the front end. If your freind doesn't want them let me know.
Car: Moving...
Engine: Running...
Transmission: Shifting...
Should Clear
SLP now sells a shortened spark plug socket to make changing your spark plugs a bit easier. Or you could just cut an inch or so off a regular spark plug socket and then weld a handle to that socket, what I had a friend do after he welded in my setup
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yep, I used my L98 heads with my 1 5/8" SLP headers, and now with my 1 3/4" SLP headers. No problems with spark plugs.
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I have the ZZ4 with the angle plug heads and SLP 1 5/8 headers. The plug clearance is fine. I can change my plugs in 20 minutes or less. The only problem is the number 6 plug. I have to go under the car for that one. I use a combo of a regular 5/8 socket, 5/8 sparkplug socket and a 5/8 wrench.
I use a heat wrap on a few wires just be sure.
evilstuie
Feb 28, 2016 03:33 PM
