Attn: For those who use CLAMPS
Old Feb 24, 2002 | 08:18 PM
stuart69427's Avatar
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
I replaced my broken Cat with a CATCO direct replacement ant it is clamped on. Exhuast leaks out and makes a bad sound becuase half the exhuast is coming from up front and the other half is coming from the back
(wouldn't be bad to have straight flow throuh, but the cops here in fairfax country are ******... )
How can I seal this without welding...that was the whole problem of getting it on...It is clamped down tight enough to start to dent the pipe on the cat a milimeter.
Old Feb 24, 2002 | 08:34 PM
89BlueTA's Avatar
They make a sealer, some sort of muffler repair, almost like a cement. I cannot remember exactly what it is called, but any auto shop should carry it. If you spread it on the pipes and then clamped it down. It should seal, I have never tried this personally, but for a few bucks it would be worth a try.
Nick
Old Feb 28, 2002 | 08:58 PM
RICHRAD's Avatar
The only time I've ever seen those clamps seal is with an air impact gun. I can't understand why that should make the difference though
Old Feb 28, 2002 | 09:26 PM
87 B4Z's Avatar
i use copper RTV and use the impact to torque them down.
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
got sealant from NAPA and it worked for a day, now its cracked.
Blocks most of the exhuast and all of the sound, still a little exhuast is let out, but it will work for now, until I get headers and y-pipe (once I find them )
Old Feb 28, 2002 | 09:28 PM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
What is a copper RTV ? ? ? ?
Old Feb 28, 2002 | 09:59 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Impact guns can generate more torque that your arms and a socket ever will.
Old Feb 28, 2002 | 10:36 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Wanna bet a cat back kit on that?
Most air impact guns are set to apply 120 lb.ft/TQ, or less, depending on cfm of the gun and/or the compressor.
Hell, I've snapped those clamps by cranking them too hard. But I'm also 6'2" and 250 lbs. So I gotta a little bit of weight to apply to it.
If you look in JC Whitney, or even Jeg's or Summit (not sure on those two) you will find a clamp that has a full 360* seal. They incorperated the clamping piece with one narrow strip instead of the two running along next to each other like ordinary ones. This blends better with the 'ring' portion to obtain a better seal.
Good luck,
AJ
OH. BTW, I know for sure that Dynomax (& others I'm sure) make stainless steel band clamps. They're just that, a steel band about 2-3" long that fully wrap around the pipe. They work real well, but cost $$$. By the time you spend the $$$, you could have it welded. But these offer the ability to remove the exhaust to drop the trans, gas tank, etc.
Old Mar 1, 2002 | 07:55 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
When I put a straight pipe in where the cat was and used U shaped clamps it leaked out the sides a bit. I took it apart again and applied some sort of generic muffler sealer and it worked fine with the same clamps until I replaced the whole exhaust system many years later.
Old Mar 2, 2002 | 11:56 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
I would say try a band clamp, too. They're like $8 bucks (I got one that was meant for desiel exhaust... oh well), but they work really well, esp. if you're going from 2.25" to 3" and you have 3 reducers. Arg.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
no green
Jan 9, 2016 09:22 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
83 Crossfire TA
Sep 18, 2015 12:01 PM
Doobie52
Sep 11, 2015 06:19 PM
