What Should I do?? Manifold or Headers??
Old Feb 24, 2002 | 09:41 PM
IrocJT's Avatar
I have a 90 Iroc with TBI (see sig) and would like to upgrade from my super restrictive boat anchors, but have very little $ to do this with...
I am wonder if you guys think it would be worth upgrading to L98 manifolds (and if you think I can get them cheap) and a better y-pipe. Would I gain much power off this??
OR, if I should just fork out the cash for a set of headers. And how important is coating?
One other reason that I am considering using manifolds is due to a requirement in the Camaro Mustang racing league (which I hope to eventually race in).
Thanks,
JT
Old Feb 24, 2002 | 09:54 PM
87transam5.7tpi's Avatar
if I were you and wanted something along the cheaper line. get the hedman's for $105 through jegs with the $100 ypipe. the coating will lower underhood temps and make em look kick ***. but the cheaper thing to do would be to order them uncoated, then brush off the paint that is on em. and put on some hitemp 1300deg silver or somthing from a parts store.
Josh
Old Feb 24, 2002 | 10:08 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
get headers
Old Feb 24, 2002 | 10:38 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Don't even waste your time on manifolds just save up to get some headers. Like mentioned above you can pick up some cheap ones, but be sure to get a new y-pipe.
Old Feb 25, 2002 | 01:23 PM
IrocJT's Avatar
Alright, well I will save up for some headers...
I see that hedman has some long tubes for our cars ($104.99). Are they any good? How bad is the install?
Oh yeah and one more thing, is header wrap worth it? I've heard both good and bad, I'm just worried about under hood tem.
Thanks,
JT
Old Feb 25, 2002 | 03:25 PM
Car: 99 Formula
Axle/Gears: 342
Your under hood temps will be fine, although coating would be good. Don't waste your money on header wrap. If oil drips down on them, you run the risk of fire, and moisture can get under them and speed up rusting.
Old Feb 25, 2002 | 03:35 PM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
header wrap caused our header on the spitfire to crack.
install is no fun.
Old Feb 25, 2002 | 03:36 PM
Tom84L69's Avatar
Car: 84 Z28
my bad, the spitfire is my little racecar i sig.
Hotrodboba400
Dec 10, 2019 07:07 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
Jlanz55
Sep 6, 2015 07:28 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
