Loudmouth on a thirdgen?
Old Mar 5, 2002 | 10:18 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
i have an 89 GTA which i am putting SLP headers on very shortly... i am wondering though... i want to put Loudmouth exhaust on my car... can i do this... will it fit on right? if not i will probably go with either the SLP exhaust... anyone know anything about that?
Old Mar 5, 2002 | 12:20 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
it won't bolt up to the cat, but Zepher has a 4th gen pacesetter exhaust on his car along with a slip-on cat, so I would guess that at most you'd have to go with a slip-on cat, or weld the old exhaust's cat flange onto the loudmouth pipe.
I'm hoping for a definate answer too, because I'd like to use the loudmouth on my car.
Old Mar 5, 2002 | 02:17 PM
Tas's Avatar
Tas
if you added a 3" pipe from your cat to halfway to your axle, the loudmouth it should be perfect. Most 4thgen catbacks don't come as far forward as thirdgen ones. I've explained this before with pictures about a month ago if you want do do a search on this board with my name.
Old Mar 5, 2002 | 02:29 PM
Timmys88Z's Avatar
You can also buy just the Loudmouth resonator and do your own piping.
Old Mar 5, 2002 | 04:37 PM
Tas's Avatar
Tas
Since I already have the 3" pipe I might do that. I need to ask the local muffler guy how much for two 2.5" pipes with a flowmaster Y would be. Plus my 4thgen Z tips on the end.
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
fastrs1891
South Central Region
Oct 20, 2015 09:24 AM
Exxon Limited
Aug 9, 2015 08:13 PM
