What header gaskets are you using with SLP headers
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I have SLP 1 5/8 headers on my ZZ4 TPI. I am having continuing problems keeping fresh air out of the headers and screwing up the O2 sensor readings. First it was the copper Mr Gaskets leaking, then the old A.I.R. tube holes I had tapped and run bolts down. Now it's either the Dead Soft Aluminum header gaskets I put on or a slight mis-alignment of the driver side (also O2 side) y-pipe to header flange mount.
I am leaning towards the misalignment of the header flange now, especially since I installed the deadsoft gaskets. They really seemed to conform to the headers and all bolts are TIGHT!
Anyone else run into this problem?
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
i have heard of a fw people having problems with the gskets that SLP supplies.
i just ordered my headers from them and used my own hardware, gaskets, etc.
i get the fel pro ones from autozone. they should have them in stock. they work great. i havent had a leak in 2 years.
-brian
-brian
Car: 1991 Camaro RS
ill have to check...it was the stock ones for the car, they worked out ok. i checked the size of the opening compared to the header, and it didnt interupt the air flow.
-brian
-brian
Chad Speier
Sep 24, 2015 12:32 PM
