Flames!!
Old Mar 10, 2002 | 04:24 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
Flames!!
I am just trying to get more flame out of my exhaust when I up/down shift
every now and then I can get my exhaust to get two flames out but not all the time
I have my cats removed though there is still a pipe going into the exhaust like there would be with the cat
I know that the pipe will help make the air/fuel mixture go off but would it make the mix burn in whole before it hits my tail pipe leaving me with no flame. or if I remove it would I prevent the flames from going out my tailpipe b/c I am not having that extra air
I just want to spit flames if I rev up to 6k rpms and then let off the gas
Old Mar 10, 2002 | 05:54 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I believe there's a way if you run a spark plug wire. Does rotary even have plug wires.
Old Mar 10, 2002 | 07:19 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
yeah they have spark plugs and wires
but I am not wanting to do it that way where I have to push a switch or anything
I want them only to come out when I upshift or downshift at high rpm and that is it
Old Mar 11, 2002 | 04:19 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
ok come one someone must knw how to get better flames on my shifts
Old Mar 11, 2002 | 08:14 PM
camaroguy2003's Avatar
Car: 1992 Camaro RS
Engine: 406 SB
Transmission: TH350
run it real real rich and it might do it, spark plug way is the best but you have to have model t coils which are hard to find.
Andrew
Old Mar 11, 2002 | 11:24 PM
VampireHunterC's Avatar
go to www.tailpipeflames.com
Old Mar 11, 2002 | 11:25 PM
Oh, well, CRAP! I just checked the site and it is gone!
Old Mar 11, 2002 | 11:37 PM
cobrakiller1989's Avatar
this is the best i could come up with
http://204.244.174.73/~blak94gsx/mo...er/rx7_bang.mpg
:lala: :lala: :lala: :lala: :lala:
Old Mar 12, 2002 | 11:15 AM
Cargasm's Avatar
That was funny as hell!
Old Mar 12, 2002 | 06:23 PM
Car: 1992 Camaro RS
Engine: 406 SB
Transmission: TH350
Search for flame throwers. We had a long discussion about it a while back.
Andrew
Old Mar 12, 2002 | 08:54 PM
fiream's Avatar
Car: 1983 Pontiac Firebird
Engine: 400HP 350
Flame????
http://www.hotrodsetc.net/2belly_2.mpg
Old Mar 12, 2002 | 09:34 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
ok not trying to go for the flip the switch flames
but only when I switch gears
the car already does it every now and then kinda like they do when racing.. but I want bigger flames
Old Mar 12, 2002 | 09:54 PM
Car: 1992 Camaro RS
Engine: 406 SB
Transmission: TH350
Try running it richer than it is now and see if it does what you want. Remove the cat if not done already, run straight pipes with no mufflers, everything to increase the velocity of the air leaving the motor. The smaller the pipe I think the more chance of seeing the flames would be, the bigger the less chance of seeing them even if they are there. That's about the only things I can think of right now but I'm tired and going to bed now, I'll come up with more ideas sometime.
Andrew
Old Mar 13, 2002 | 12:20 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
right now I am running two 2" pipes off the block into a collector.
then it goes into a y and back into dual 2 inch pipes again
what I am planning on doing is just going to true dual 2 inch pipes
into a 2 1/2 inch core muffler ( all straight through )
car runs a little rich as it is. so that is taken care of.
and I dont have a cat, running a pre-silencer instead.
one of my mufflers is blown and I am sure that the y pipe's are not helping my flames any
my only problem with running rich though is I dont want to have a loss of power nor fuel econ.
though would leaving hte air pump in or taking it out help with flames or no difference
thanx for the input so far guys
just tired of getting little puffs of flames
I want some huge *** flames from my ***
I have yet to beat the guy around here in his RX-7 who is running a 4 inch pipe off his turbo at a flamage contest
Old Mar 13, 2002 | 02:35 AM
Jza's Avatar
Jza
How about running another coil and a spark plug, but using a signal wire from your normal coil so it's sparking constantly. You could even switch it. :shrug: (constant flamage/no flamage)
Old Mar 13, 2002 | 03:15 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Old Mar 14, 2002 | 11:49 PM
Azure's Avatar
From: "No one cares if you're in before the lock!" - Best quote ever.
How about running the spark plug.....er...lol.......sorry, RX, I just couldn't help myself...
Old Mar 15, 2002 | 12:32 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
why didn't I ever think of that
SMART ***
Old Mar 15, 2002 | 07:33 AM
MikeS's Avatar
This is just me thinking here....
I know what it is you're looking for. I remember the M3's spit flames a lot on the shifts at the Petit LeMans at Road Atlanta. I'm thinking the best way to make it visible is to reduce the length of your exhaust system. Of course, this can't always be done since the tips are usually at the rear of the car. Maybe a side setup would be shorter and work, but might not work on an rx7, or just might look funny, I don't know.
Old Mar 15, 2002 | 10:54 AM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
check this out http://www.hotrodsetc.net/flamekit.html that came from http://www.hotrodsetc.net/
Old Mar 15, 2002 | 11:06 AM
nice flames!!
Old Mar 15, 2002 | 03:52 PM
Jza's Avatar
Jza
Here, let me try again..
How about running another coil and a spark plug, but using a signal wire from your normal coil so it's sparking constantly. <strike>You could even switch it. :shrug: (constant flamage/no flamage)<strike>
Old Mar 16, 2002 | 12:45 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Re: Flames!!
ok so I know I am being a pain in the ***
but hey flames are sweet man
I wouldn't mind having the switch thing to be honest but too much work to switch gears hit the switch and then spit the flames
though wouldn't mind getting something like that for if I want to sit at and idle and spit them out
the short exhaust idea might work but after I get my springs for the car I do not think I would have the room to do so since I should only have an inch of space under my car when I drop it all the way and I am trying to go with dual 2-2 1/2 inch pipes for my car (hehe I am running an 80 cid motor and run pipes just as big as you guys)
also most aftermarket muffs have the tip (damn 3-4 inch suckers though ) as part of the muffler
though I might be able to get a spart/coil as you said with something to set it off right at 7400-8500 rpms depending on if my mods i am doing ( no more turbo for me though for now ) will move my shift point up
Old Mar 16, 2002 | 01:16 AM
Jza's Avatar
Jza
You're not getting what I was saying. Even if it's sparking all the time, I don't think it would actually ignite the exhaust until you let off the gas, which is what you'd be doing on an upshift anyway.
Anyway, I was being the pain in the ***, not you.. lol
Old Mar 16, 2002 | 01:30 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
I understand
only problem is with this car I would prolly set it off most the time if had it without a switch
I run a little rich and not much I can do about that
Old Mar 16, 2002 | 03:33 AM
JPrevost's Avatar
Car: 91 Red Sled
hehehe
Old Mar 16, 2002 | 04:54 PM
What the hey is that thing JPrevost?
Old Mar 16, 2002 | 05:40 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Its called a lighter and an aeresol can!
Old Mar 17, 2002 | 02:17 AM
Jza's Avatar
Jza
No lighter.. It's the "Torpedo" setting it off, I think.
JPrevost: closet pyro :sillylol:
Old Mar 17, 2002 | 02:54 AM
JPrevost's Avatar
Car: 91 Red Sled
That's my friend playing with our space heater .
I'm no pyro, just a guy that likes the smell of fuel and fire.
db057
Apr 28, 2019 07:45 AM
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
2012sergen11
Oct 13, 2015 07:38 PM
Hello, Michael
Sep 11, 2015 01:10 PM
buckshot63
Sep 10, 2015 09:15 AM
