True duals in to one muffler, goo or bad?
Old Mar 13, 2002 | 12:50 AM
SMKNGTA's Avatar
Car: 1989 GTA
Axle/Gears: 9bolt 3.27s
I have true 2.5in duals on my 89 GTA and I want a different sound. Hooker offers the Aerochamber muffler with dual 2.5in inlet and single 3in outlet, would this work like an X or H pipe or would it hurt my performance? Would this sound like the Hooker catback? Thanks
Old Mar 13, 2002 | 02:12 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
you would be best off going with an X-pipe
this setup you are talking about here would not really work that great as a x-pipe setup
though as far as placement for the x-pipe if you are to put one on your car is dependent of what RPM's you want to get the best scavaging at
though as a starting point you can take the distance from your exhaust port and then take that same distance from the collector and put your x-pipe there
in theory I think that should give you a good reversion low pressure wave for the exhaust gas to flow from the exhaust valve out of and reduce the restriction
if you dont understand this I am sorry I am half passed out at the moment and I hopoe someone else can go further into what I am trying to say
Old Mar 13, 2002 | 05:27 PM
Momar's Avatar
distance from your exhaust port and collector to where?
Frozer!!!
Jan 19, 2024 04:55 PM
beastin91rs
Oct 9, 2015 07:38 AM
formula_novice
Sep 5, 2015 03:58 AM
Dialed_In
Aug 20, 2015 01:45 PM
