How do i reroute the exhaust for my SFConnectors?
Old Mar 14, 2002 | 09:59 PM
CRZYTRN-92Z28's Avatar
Car: 1992 Z28
Engine: 350 L98 w/ D-1SC
Transmission: POS 700-R4
Ordered comp. engineering SFC's and my cats are in the way on the passenger side. How can I make this work?
Old Mar 16, 2002 | 01:39 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Either you adjust the exhaust by loosening, moving, and re-tightening the connections.
OR
Buy modified SFC's for this specific purpose.
ONE THOUSAND POSTS!!!
Old Mar 20, 2002 | 02:37 PM
Fast3rdGen's Avatar
didn't you see?
didn't you see the disclaimer that says "will not clear factory routed exhaust"? :doh!nly connectors i ever found that will clear are the jegster bolt-ins from jegs.
Old Mar 20, 2002 | 03:43 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
i'm gonna get them jegster bolt in's and everntually have them welded. has anyone had any problems with them?
Old Mar 20, 2002 | 05:12 PM
Fast3rdGen's Avatar
i run them
i use them.....fits tight up against the floor board and the passenger side follows the contour of the floor pan to go over top of the cat area. i would definately recomend them. they prove excellen support and will give a good foundation for drive shaft loop and ladder bar x-members when you weld them in.
Rich
zapr
Jul 27, 2018 06:03 PM
PurelyPMD
May 5, 2016 04:57 PM
86White_T/A305
Mar 6, 2016 01:48 PM
david068513
Sep 18, 2015 10:36 AM
gta892000
Sep 16, 2015 12:37 AM
