exhaust performance?
Old Mar 20, 2002 | 02:24 AM
riggs58's Avatar
I have a '87 Iroc (305 TPI) that needs to have the exhaust system replaced, still has stock system. I am looking at both SLP and Hooker cat back systems. What type of performance can I expect from each system respectively aside from just sound improvement. I' ve read that if an exhaust system has too little backpressure low end torque is sacrificed. This is the last thing I want since I have little to begin with. What type of system should I be looking at to improve sound but not at the expense of low end torque? Any additional exhaust system recommendations would be greatly appreciated. Thanks.
Old Mar 20, 2002 | 08:12 AM
1989camarorsrs's Avatar
Both hooker and slp are realy good so whateva u want go for it, I realy dont think the cat backs make u lose torque but def help in the hp area with some 10 extra hp high end
Old Mar 20, 2002 | 10:09 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I'd say go for the Hooker, it's cheaper for one. I definately noticed it pulled harder once I got it put on and this was the day after I got 3:73s installed. Backpressure won't help torque or anything else, you don't want any backpressure. Get yourself some headers first if you don't have them.
Old Mar 20, 2002 | 10:13 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
mark, if you keep posting about the hooker cat-back I will have to just go and buy one for my car. Seriously I am thinking of going with the hooker set up. Im not sure which headers to go with. Hedman, or hooker. long or shorties.
Old Mar 20, 2002 | 04:18 PM
riggs58's Avatar
Thanks very much for the replies. In addition, can someone tell me what a Y-pipe is and if an aftermarket one, such as the SLP, improve performance also. Thanks. :rockon:
Old Mar 20, 2002 | 06:39 PM
87 B4Z's Avatar
if you really want performance out of a cat back you cant go wrong with SLP. i had slowmaster on my car and the best i could run was a 15.2, i switched to the SLP setup and i now run a 14.9. i would accpect the hooker to be about the same as the slowmaster.
Old Mar 20, 2002 | 07:10 PM
Tas's Avatar
Tas
That's pretty impressive. What was the MPH differances? was the catback the only differance? Did they both have 3" pipes?
Old Mar 20, 2002 | 07:49 PM
87 B4Z's Avatar
the 1/4 mile mph went up alittle, 90.0 to 90.8, but the 1/8th went up 70.? to 72.? and the 1/8 ET droped also. it is definitely faster i ran a 2 15.0's and a 3 14.9. i even ran a 15.1 with my friend riding with me that night.
Old Mar 20, 2002 | 08:12 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Delta Series Flowmaster if you'd rather have performance than just sound.
Old Mar 20, 2002 | 08:51 PM
Black 84 Z's Avatar
Car: 1984 Z28
Engine: 350ci
Axle/Gears: 3.73 12 bolt
I'd bet that the drop in ET is more attributable to driver improvement or better conditions than to the muffler swap. The similar MPH numbers generally indicate similar HP. I'm not saying that it isn't stronger, but .3 secs is a lot when only going from one performance type exhaust to another.
DG
Hotrodboba400
Dec 10, 2019 07:07 PM
Djmathis123
Sep 8, 2015 08:42 PM
scottmoyer
Sep 7, 2015 07:06 PM
Formula_88AE
Sep 3, 2015 01:47 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
