could a clogged cat make my secondaries not open much?
Old Mar 24, 2002 | 07:24 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
cuz my secondaries barely open and i have the a/v tension right so its not that.......and when i floor it i hear a clicking noise and a rushing air kind of noise........
Old Mar 24, 2002 | 11:58 PM
86maro305's Avatar
i really don't think that a clogged up cat would do that. do you have the stock q-jet or not.... because if you do the secondaries don't really open very wide ever. the sucking noise is just the carb getting air its normal. what i did is got a non-computer controled carb, new distributor and got rid of that q-jet and im happy with that. it is costly but worth every dime.
Old Mar 25, 2002 | 12:56 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
its the stock carb Q-jet
there is definately something wrong cuz my car will do nothing but bog past 1/2 throttle or so....its horrible
and the secondaries DO open bigger than they are now cuz i remember when i was adjusting the A/V tension they would open pretty far......and i probably WILL do that swap....but that will b when i get a new motor for it....its not really worth it on this motor
Old Mar 25, 2002 | 01:32 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
if you have any vac secondary carb and then put a restriction in the exhaust (like your clogged cat) you will have them open slower and prolly not as much
the problem is the backpressure from the clog in the cat will prevent that spent mixture from getting out of the cyl so since you have less volume in the cyl to pull in a fresh intake charge you are not going to pull as much vac therefore slowing down your opening of the second plates in the carb
or so I am thinking
Old Mar 25, 2002 | 10:54 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
well they are mechanical secondaries.....but wouldnt they still work on some kind of vacuum?
cuz i was kinda thinking the same way u were RX7speed
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Infested
May 22, 2018 11:56 PM
onefreakz
May 14, 2018 12:15 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
