A.i.r. Tubes
Old 03-27-2002, 11:15 PM
silver89Rs's Avatar
A.i.r. Tubes
WHEN I REMOVE THE AIR PUMP COULD I JUST TAKE THE RUBBER HOSES OFF THE AIR TUBES (RIGHT BEFORE THE CHECKVALVES) OR DO I HAVE TO REMOVE THE TUBES AND PLUG THE HOLES?
Old 03-30-2002, 01:04 AM
Mista's Avatar
Car: 1986 Trans Am
Engine: 305 TPI peanut cam
remove the tubes (#8 is really a PITA) and plug the holes with 1/4" NPT brass pipe plugs. Will also need to plug the SS hard line going to the converter. A short piece of the rubber hose you take off, trim to 2" long, and use a 3/8" NPT plug. Use a leftover stock clamp to secure.
Old 03-30-2002, 11:58 AM
vic_V8's Avatar
Car: RS
Transmission: 4L60
you can either plug the air lines themselves (one for each side) or remove them a plug the manifolds, I recomend the latter, once you get this done you'll realize that you have twice as much room to remove spark plugs, etc.
Old 03-31-2002, 04:22 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
Will you still be able to pass DEQ without the AIR Tubes and smog pump?? I would love to take that crap off.
Old 04-02-2002, 08:17 AM
84TAProject's Avatar
My mechanic said that a smog pump makes no difference in emmisions. In fact, my car with no smog pump easily went through emmisions. The car went through better than my 2.8 and its got a 305. I live in CT, and we have some pretty strick standards around here.
gixxer92
05-18-2017 11:20 AM
no green
01-09-2016 09:22 PM
Cam-aro
Camaros Wanted
11-12-2015 03:35 PM
FormulasOnly
10-02-2015 05:52 PM
zman1969
10-01-2015 11:09 AM
Quick Reply: A.i.r. Tubes
